Combining strings / rtos / strcat
thomas.schive
thomas.schive
Hello!
I'm trying to write a routine that does something like this. First of all the user puts in two values - one "constant" and one that's supposed to increase by one per click. As an example would this be useful for naming objects, if you have 10 boxes that should be named 60E1-1, 60E1-2, 60E1-3 and so on ...
I want the name to appear where the user clicks on a new created layer. Most of it is working, but I'm struggeling with combining the user inputs with strcat as I want to call it an integer, but then I'm not able to combine, and it won't write anything with my rtos now (I think).
Maybe you pros can find the problems here?
;;Message to user
(princ "Write TBP to begin ... ")
;;Cleaning up
(defun LM:gpp ( / )
    (vl-load-com)
    (setq
        cmdech (getvar "CMDECHO")
        oldlay (getvar 'clayer)
    );_ setq
    (setvar "CMDECHO" 0)
);_ defun
;;Getting input
(defun LM:brukerinput ( / )
    (setq
        konstant (vl-string-translate " " " " (getstring T "\nWrite constant value "))
    (setq
        variabelsv (getstring "\nWrite start value ") ;;I actually want this to be a getint, as it's supposed to be a number ...
);_defun
;;Combining input
(defun LM:kombinering ( / )
    (setq
        kombinert (strcat konstant variabelsv) ;;This one fails when they're not both strings apparently
);_defun
;;Write text
(defun LM:skrivtekst ( / )
    (command "_.Layer" "_Make" "Tellelag" "_Color" "7" "" "LType" "Continuous" "" "")
    (eval
        (append
            '(command "._text" punkta)
                (if
                    (zerop
                        (cdr
                            (assoc 40
                                (entget
                                    (tblobjname "style"
                                        (getvar 'textstyle)
                    '(0.5);;Text size
            '(0
                (rtos kombinert 2 0);; And here lies (I think) my next problem, rtos maybe isn't what I'm supposed to use?
);_defun
;;mp
(defun c:tbp ( / )
    (LM:gpp)
    (LM:brukerinput)
    (LM:kombinering)
        (while
            (setq
                punkta (getpoint "\nChoose point ")
                variabelsv (+ variabelsv 1)
            )setq
            (LM:skrivtekst)
        (setvar "CMDECHO" cmdech)
        (setvar "CLAYER" oldlay)
    (princ)
);_defun
;;>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> End of routine
Regards
ts
Kent1Cooper
If you use (getint) for the 'variabelsv' variable, then use (itoa) to make it into a string that you can concatenate with 'konstant':
(strcat konstant (itoa variabelsv))
Kent Cooper, AIA
thomas.schive
Thanks, that solves that part!
Getting a "Choose point bad argument type: numberp: "60E21""
(now I wrote 60E2 as konstant and 1 as variabelsv)
I'm suspecting my rtos?
/ts
rkmcswain
Try this:
;;Message to user
;;Cleaning up
(defun LM:gpp ( / )
    (vl-load-com)
    (setq
    );_ setq
);_ defun
;;Getting input
    (setq
    (setq
        variabelsv (getint "\nWrite start value ") ;;I actually want this to be a getint, as it's supposed to be a number ...
);_defun
;;Combining input
    (setq
        kombinert (strcat konstant (itoa variabelsv))
);_defun
;;Write text
    (eval
        (append
                (if
                    (zerop
                        (cdr
                            (assoc 40
                                (entget
                                    (tblobjname "style"
                                        (getvar 'textstyle)
                    '(0.5);;Text size
            '(0
                kombinert
);_defun
;;mp
(defun c:tbp ( / )
    (LM:gpp)
    (LM:brukerinput)
    (LM:kombinering)
        (while
            (setq
            )setq
	    (LM:skrivtekst)
	    (LM:kombinering)
    (princ)
);_defun
I didn't evaluate the code as a whole, just edited it enough to get it to work.
R.K. McSwain     | CADpanacea | on twitter
thomas.schive
This worked great, thanks!
/ts
