combine layer lsp
combine layer lsp
combine layer lsp
hello. thank you for made these lsps.
I want to combine the two lsp into one. always thank you experts
(defun c:bl (/ SetLayer obj acdoc blocks)
  (vl-load-com)
  (defun SetLayer (blockName layerName)
    (vlax-for obj (vla-Item blocks blockName)
      (vla-put-Layer obj layerName)
      (if (= (vla-get-ObjectName obj) "AcDbBlockReference")
        (SetLayer (vla-get-Name obj) layerName)
  (if (and (setq obj (car (entsel "\nsame layer inside block")))
           (setq obj (vlax-ename->vla-object obj))
    (progn
      (setq acdoc  (vla-get-ActiveDocument (vlax-get-acad-object))
            blocks (vla-get-Blocks acdoc)
      (SetLayer (vla-get-Name obj) (vla-get-Layer obj))
      (vla-Regen acdoc acActiveViewport)
  (princ)
(defun c:br (/ ELST ENAM ESEL BNAM FLST)
(setvar "cmdecho" 0)
  (vl-load-com)
  (setq ESEL (entsel "\nbylayer inside block")
 ENAM (car ESEL)
 ELST (entget ENAM)
 BNAM (cdr (assoc 2 ELST))
 FLST nil
  (fix1 BNAM)
  (vl-cmdf "regen")
  (princ)
(defun FIX1 (BNAM / BENAM)
  (if (not (member BNAM FLST))
 (progn
   (setq FLST  (cons BNAM FLST)
  BENAM (tblobjname "block" BNAM)
   (while (setq BENAM (entnext BENAM))
 ;(print (entget BENAM))
 (if (= (cdr (assoc 0 (entget BENAM))) "INSERT")
   (fix1 (cdr (assoc 2 (entget BENAM))))
   (vla-put-color (vlax-ename->vla-object BENAM) 256)
  (princ)
dbhunia
Do you need this....... The easiest way to combine ....... 🙂
(defun C:CBL ( / con )
	(defun bl (/ SetLayer obj acdoc blocks)
	  (vl-load-com)
		(progn
	  (princ)
	(defun br (/ ELST ENAM ESEL BNAM FLST)
	  (vl-load-com)
			 ENAM (car ESEL)
			 ELST (entget ENAM)
			 FLST nil
	  (fix1 BNAM)
	  (vl-cmdf "regen")
	  (princ)
	 (progn
	  (princ)
	(initget "Bylayer Samelayer")
	(setq con
	 (cond ((getkword "\nEnter Required Option [Bylayer/Samelayer] inside block <Bylayer>: " )) ("Bylayer"))
	(cond ((= con "Bylayer") (br))
	      ((= con "Samelayer") (bl))
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
oh, always thank you dbhunia  help me but
I do not want to use this
 (cond ((getkword "\nEnter Required Option [Bylayer/Samelayer] inside block : " )) ("Bylayer"))
I made like it, and not working. please check it one more. thank you
  (vl-load-com)
    (progn
(br)
  (princ)
  (vl-load-com)
  (setq ESEL (entlast)
 ENAM (car ESEL)
 ELST (entget ENAM)
 FLST nil
  (fix1 BNAM)
  (vl-cmdf "regen")
  (princ)
 (progn
  (princ)
marko_ribar
You mean :
(vl-load-com)
(progn
(br (vlax-vla-object->ename obj))
(princ)
(defun br ( ENAM / ELST BNAM FLST)
(vl-load-com)
(setq ELST (entget ENAM)
FLST nil
(fix1 BNAM)
(vl-cmdf "regen")
(princ)
(progn
(princ)
Marko Ribar, d.i.a. (graduated engineer of architecture)
dbhunia
check this.......
	(vl-load-com)
		 (progn
	(progn
  (fix1 (vla-get-Name obj))
  (vl-cmdf "regen")
  (princ)
Debashis Bhunia
