combine 2 lisp functions for rotate viewports in selected layouts
jtm2020hyo
jtm2020hyo
R2CP: rotate selected objects to one center point.
ROTATEMULT: rotate multiple blocks the same time,  linear rotation, I mean this lisp add any value to actual rotation value.
processviewportsinallsellayouts_v2: move all viewports inside selected layouts
so I need a hero to combine those lisp function for move / rotate circular / rotate radial, all viewports inside selected layouts ,and If possible do the equivalent to mirror. all that add to "processviewportsinallsellayouts_v2" lisp.
devitg
Please upload your sample.dwg where you will apply such lisp
jtm2020hyo
REPLY 1 OF 3
PROCESSVIEWPORTSINALLSELLAYOUTS_V2:
1 select layout
2 choice option "PICK" in Promp bar
3 pick 2 points
4 work done
jtm2020hyo
REPLY 2 OF 3
R2CP:
Rotate selected block to one point.
1 select blocks
2 choice center point
3 enter offset angle  (90 degrees in the drawing )
4 all selected blocks aim one center point
jtm2020hyo
REPLY 3 OF 3
ROTATEMULTIPLE:
add an offset to block angle
1 select block
2 introduce any number (36 degrees in the drawing)
3 lisp will add an offset angle to all selected blocks
