Code issues
Code issues
Isanders2
Code issues
Isanders2
Hello I found this old code and I’m running into an issue where it resets all my snap values essentially only allowing nearest snap to be selected was wondering if someone can figure out the issue
; -----TWST----- DVIEW TWIST & SNAP ANG
;;;  LISP  uses two points or an input angle to
;;;    twist the current view using the the dview command.
;;;    the snapangle variable is reset to make the cursor
;;;    appear horizontal.
;;;;The dtr funtion converts degrees to radians
;;;;The rtd funtion converts radians to degrees
(defun RTD (/ANG) (/ (* ANG 180.0) pi))
(defun DTR (/ANG) (* pi (/ ANG 180.0)))
(defun C:TW (/ P1 P2 ANG)
;;;  store the cmdecho, osnapcoord, osmode and orhtomode system varibles
  (setq CE-SAV (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq OSCOORD-SAV (getvar "osnapcoord"))
  (setvar "osnapcoord" 1)
  (setq OSMODE-SAV (getvar "osmode"))
  (setvar "osmode" 512)
  (setq ORTHOMODE-SAV (getvar "orthomode"))
  (setvar "orthomode" 0)
  (princ
    "\nTwist view and cursor angle by picking two point or entering an angle
  )					; _ end ofPRINC
  (if (setq P2 (getpoint
		 "\nFirst point(left) <Press Enter to input an angle>: "
	       )			; _ end of GETPOINT
      ) ;_ end of SETQ
    (progn (initget 1)
	   (setq P1  (getpoint "\nSecond point(right): " P2)
		 ANG (angle P2 P1)
	   ) ;_ end of SETQ
	   (command "DVIEW" "L" "" "TW" (- 360 (RTD ANG)) "")
	   (setvar "SNAPANG" ANG)
    ) ;_  end of PROGN
    (progn (setq ANG (getangle "\nAngle: "))
    ) ;_ end of PROGN
  ) ;_  end of IF
  (setvar "cmdecho" CE-SAV)
  (setvar "osnapcoord" OSCOORD-SAV)
  (setvar "OSMODE" OSMODE-SAV)
  (setvar "orthomode" ORTHOMODE-SAV)
;;; print the rotation angle to the screen:  converts string to local units
  and
  precision
  (princ
    (strcat "\nTwist angle: "
	    (angtos ANG (getvar "aunits") (getvar "auprec"))
    ) ;_ end of strcat
  ) ;_ end of princ
  (princ)
) ;_  end of DEFUN
; -----SNAG----- SET SNAP ANG TO DVIEW TWIST
(defun c:snag (/ VANG SANG)
  (setq VANG (getvar "viewtwist"))
  (setq SANG (- (* 2 pi) VANG))
  (setvar "snapang" SANG)
paullimapa
These lines of code at the beginning is what's removing all your running object snap settings and setting it to near:
  (setvar "osmode" 512) ; set object snap
Now for the code to work properly you really don't want to have any running object snaps set
otherwise the results will be wrong. But what should be done is saving the current running osnap setting first before changing it so that by the end of the code everything can go back to the way it was. So what I would do is first save the current running object snap settings but not set it to nearest instead set it to none so the code will look like this:
  (setq osmode (getvar "osmode")) ; save current object snap settings
  (setvar "osmode" 0) ; set object snap to none
 Then towards the end of the code where these lines of code is shown:
add an additional line of code to restore the original running object snaps:
(setvar "osmode" osmode) ; restore original running object snap settings
Paul Li
IT Specialist
@The Office
EnM4st3r
So what I would do is first save the current running object snap settings..
isnt that already done using the Variable  OSMODE-SAV?
EnM4st3r
maybe try adding a Error function for restoring the variables
(defun C:TW (/ *error* CE-SAV OSCOORD-SAV OSMODE-SAV ORTHOMODE-SAV P1 P2 ANG)
  (defun *error* (msg)
    (if CE-SAV (setvar "cmdecho" CE-SAV))
    (if OSCOORD-SAV (setvar "osnapcoord" OSCOORD-SAV))
    (if OSMODE-SAV (setvar "OSMODE" OSMODE-SAV))
    (if ORTHOMODE-SAV (setvar "orthomode" ORTHOMODE-SAV))
    (princ (strcat "Error: " msg))
    (princ)
EnM4st3r
whats with "and precision"?
  and
  precision
  (princ
should it be like that?
;;; print the rotation angle to the screen:  converts string to local units and precision
  (princ
paullimapa
Oops you are correct l don’t know how I missed that. So if the function runs its course properly the running osnap setting should be restored back to the original settings. Is that not happening for you?
Paul Li
IT Specialist
@The Office
Isanders2
I ended up find8ng a work around be deleting two lines instead so it didn’t end up reading the osnap settings
