Closest distance from a point on a curve to the start or end of the curve
Browning_Zed
Browning_Zed
Hi all,
I am trying to find a solution how to get the distance along a curve from a specified point lying on the curve. I specify a point in this way:
(setq
    curveobj (entsel)
    closepnt (vlax-curve-getclosestpointto (car curveobj) (cadr curveobj))
Now I need the following steps:
1. Find out the distance from closepnt to the start of the curve;
2. Find out the distance from closepnt to the end of the curve;
3. Compare these two distances, and if distance 1 is less than distance 2 then return T, otherwise nil.
Thanks in advance for your help.
ВeekeeCZ
Browning_Zed
Thanks man, you're great as always. I did it thanks to you.
(setq
    enselobj (entsel)
    curveobj (car enselobj)
    startdis
        (vlax-curve-getDistAtPoint
            curveobj
            (vlax-curve-getclosestpointto curveobj (cadr enselobj))
( < startdis
    ( - (vlax-curve-getDistAtParam
            curveobj
            (vlax-curve-getEndParam curveobj)
        startdis
