Closed polyline trim into another closed polyline
aitorm
Message 1 of 13
aitorm
Imagine I have a closed polyline in autocad and then I create a line that cut the polygon in two vertex. I would love to have a lsp that ask me which side of the polygon to remove and subsitute the old polyline with the new cutted one.
But I don't know how to write lsp code, would you give me a hand?
Thank you
Replies (12)
Message 2 of 13
hak_vz
You can use command BOUNDARY. It does what you ask.
Alternatively here is my code to avoid dialog and speed all up.
(defun c:clipClosedPoly (/ *error* pick e  pt pts)
	(defun *error* ()
		(setvar 'cmdecho 1)
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ)
      (princ)
	(defun pick (msg)
		(setq e (car(entsel msg)))
		(if (and (not e) (= (getvar 'Errno) 7)) (pick msg) e)
	(setq eo (vlax-ename->vla-object (pick  "\nSelect polyline >")) e nil)
	(if (/= (vlax-get eo  'ObjectName) "AcDbPolyline") (pick  "\nSelect polyline >"))
	(setq lo (vlax-ename->vla-object (pick  "\nSelect section line >")) e nil)
	(if (not (member(vlax-get lo  'ObjectName) '("AcDbLine" "AcDbPolyline"))) (pick  "\nSelect section line >"))
	(initget 1)
	(setq pt (getpoint "\nSelect point inside area to retain >"))
	(setvar 'cmdecho 0)
	(command "-boundary" pt "")
	(setq pts (vlax-get (vlax-ename->vla-object (entlast)) 'coordinates))
	(vlax-put eo 'coordinates pts)
	(entdel (entlast))
	(vla-delete lo)
	(setvar 'cmdecho 1)
	(princ "\nDone!")
	(princ)
Miljenko Hatlak
Message 3 of 13
Kent1Cooper
Can you just use BPOLY [or BOUNDARY] to make the side you want to keep?  Just a single pick in the side you want.  And ERASE the full-sized one.
Kent Cooper, AIA
Message 4 of 13
calderg1000
Regards @aitorm
Try this code, it uses the standard method to do the clipping, and it gives you the option of closing the resulting polyline or leaving it open.
(defun c:nt( / s )
  (princ "\n Trim Objects Lwpolyline in Mode 'Standard'")
  (command "_trim" "o" "s" pause "" (setq s(entsel "\nSelect the side of the lwpolyline to crop...")) "")
  (Initget 1 "Y N")
  (setq opc(getkword"\nDo you want to close the clipped polyline...[Y/N]<Y>:"))
  (if (=  opc "Y")
  (entmod (subst(cons 70 129)(assoc 70 (entget(car s)))(entget(car s))))
  (princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 5 of 13
aitorm
Thank you for your lisp!! It works like a charm!!!
Message 6 of 13
aitorm
Thanks, but I need this command in a drawing with too many things, boundary would require many more steps (cleaning before and after).
Message 7 of 13
aitorm
Loved it, favourite solution so far!! Just works very similar to trim command, and thats intuitive. Could be improved if it worked exactly as a trim command, for example, letting you choose several polylines and trim lines.
But more than marvellous enough with your lsp 🙂
Message 8 of 13
aitorm
I've got a little little bug. If you're cutting an arc in the polyline it will close the polyline with an arc 🙂
Message 9 of 13
calderg1000
Regards @aitorm
It should work fine with Lwpolylines with the following conditions, elevation=0 and closed. If the closure behaves like an arch. Previously apply Reverse to the lwpolyline...
Carlos Calderon G
Message 10 of 13
omarsvn
is there a way to keep two polygons? I mean, keep the original polygon just divide for the lineScreenshot (112).png
Message 11 of 13
hak_vz
@omarsvn  Try this! If you have only line segments than original polygon may be divided in n sub-polygons, and we can retain all his properties. If not than use this. It doesn't remove any original polygon or dividing line(s).
(defun c:boundaryByPickPoint (/ *error* p adoc)
	(defun *error* ()
		(setvar 'cmdecho 1)
			(princ)
      (princ)
	(setq
		i 0
		adoc (vla-get-activedocument (vlax-get-acad-object))
	(princ "\nPress <Enter> to exit loop!")
	(vla-endundomark adoc)
	(vla-startundomark adoc)
	(while (setq p (getpoint (strcat " \nPick " (itoa (setq i (1+ i))) ". point >")))
		(command "._boundary" p "")
	(princ "\nDone!")
	(princ)
Miljenko Hatlak
Message 12 of 13
omarsvn
It works good but I couldn't explain it to you really well, I dont want to keep the original polygon or the dividing line just the subpolygons, I dont know if possible separate the polygons by 0.135 when they have been divided
Message 13 of 13
hak_vz
@omarsvn Try this.
Create polygon and separating lines. Run code, select separating lines and pick areas inside main polygon.
AT the and remove original polygon.
(defun c:boundaryByPickPoint (/ *error* p adoc i eo ss sm)
	(defun *error* ()
		(setvar 'cmdecho 1)
		(setvar 'osmode  old)
			(princ)
      (princ)
	(setq
		i -1
		old (getvar 'osmode)
	(princ "\nSelect dividing lines!")
	(setq ss (ssget '((0 . "*line"))) lst (entlast) sm (ssadd))
	(while (< (setq i (1+ i)) (sslength ss))
		(setq eo (vlax-ename->vla-object (ssname ss i)))
		(vla-offset eo 0.0675)
		(ssadd (entlast)sm )
		(vla-offset eo -0.0675)
		(ssadd(entlast) sm )
	(setvar 'cmdecho 0)
	(setvar 'osmode  0)
	(setq i 0)
	(setq i -1)
		(entdel (ssname ss i))
	(setq i -1)
	(while (< (setq i (1+ i)) (sslength sm))
		(entdel (ssname sm i))
	(setvar 'cmdecho 1)
	(princ "\nDone!")
	(princ)
Miljenko Hatlak
