Close L and C shapes into squares
faugustom
Message 1 of 11
faugustom
The is any way or lisp to close all "L" (two perpendicular lines) and "C" (three lines, perpendicular, parallel and aligned) polilynes in a drawing into square closed polilynes?
Replies (10)
Message 2 of 11
CodeDing
@faugustom ,
Can you post a sample drawing with a few of these L and C shapes please? That would help a lot.
Best,
~DD
Message 3 of 11
faugustom
@CodeDing, thank you for the reply
File attached
Message 4 of 11
hak_vz
Try this
This will work with polyline entities
(defun c:ctr ( / pointlist2d ss p1 p2 p3 i eo coords  adoc *error*)
;hak_vz 29-04-2021
(defun pointlist2d (lst / ret) (while lst (setq	ret (cons (list (car lst) (cadr lst)) ret) lst (cddr lst) ) ) (reverse ret))
(defun *error* ( msg )
	(if (not (member msg '("Function cancelled" "quit / exit abort")))
		(princ (strcat "\nError: " msg))
	(if adoc (vla-endundomark adoc))
	(setvar 'cmdecho 1)
	(princ)
(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
(vla-startundomark adoc)
(setvar 'cmdecho 0)
(princ "\nSelect all line objects with a window selection >")
(setq p1 (getpoint "\nFirst point>"))(setq p2 (getcorner p1 "\nSecond point>"))
(setq ss (ssget "w" p1 p2 '((0 . "LWPOLYLINE")(90 . 4))))
(setq i -1)
(while (< (setq i (1+ i)) (sslength ss))
(setq eo (vlax-ename->vla-object(ssname ss i)))
(vlax-put eo 'Closed 1)
(setq ss (ssget "w" p1 p2 '((0 . "LWPOLYLINE")(90 . 3))))
(setq i -1)
(setq coords (pointlist2d (vlax-get eo 'Coordinates)))
(setq p1 (car coords) p2 (cadr coords) p3 (last coords))
(setq m (mapcar '* (mapcar '+ p1 p3) '(0.5 0.5)) ang (+ (angle m p2) pi) di (distance m p2))
(setq coords (append (vlax-get eo 'Coordinates)(polar m ang di)))
(vlax-put eo 'Coordinates coords)
(setvar 'cmdecho 1)
(princ "\nDone")
(princ)
After reading your request I thought that elements are lines not polylines so here is a version that works
with lines i.e exploded polylines
(defun c:ctrlines ( / pointlist2d ss p1 p2 p3 i eo coords  adoc *error*)
;hak_vz 29-04-2021
	(setvar 'cmdecho 1)
	(princ)
(setvar 'cmdecho 0)
(setq ss (ssget "w" (setq p1 (getpoint "\nFirst point>"))(setq p2 (getcorner p1 "\nSecond point>")) '((0 . "LINE"))))
(initcommandversion)
(command "_.pedit" "m" ss "" "y" "j" "" "")
(setq i -1)
(setq i -1)
(setvar 'cmdecho 1)
(princ "\nDone")
(princ)
Miljenko Hatlak
Message 5 of 11
Kent1Cooper
@faugustom wrote:
.... File attached
For the C ones, you can just select them, and in the Properties palette, change the "Closed" item to Yes.  Are you looking to do a wholesale selection of lots of them to process at once?  If so, you obviously don't want to use Properties with the L ones.
Kent Cooper, AIA
Message 6 of 11
CodeDing
@faugustom ,
Thanks for the drawing. Assuming you will not need to be selecting LINEs, then this will work for you:
(defun c:LCCLOSE ( / ss cnt e eg MultiAssoc ptList)
(setq MultiAssoc (lambda (k l / i) (if (setq i (assoc k l)) (cons (cdr i) (MultiAssoc k (cdr (member i l))))))) (prompt "\nSelect \"L\" & \"C\" shaped Polylines to Close: ") (if (setq ss (ssget '((-4 . "<AND") (0 . "LWPOLYLINE") (-4 . "<OR") (90 . 3) (90 . 4) (-4 . "OR>") (-4 . "&=") (70 . 0) (-4 . "AND>")))) (repeat (setq cnt (sslength ss)) (setq e (ssname ss (setq cnt (1- cnt)))) (setq eg (entget e)) (setq ptList (MultiAssoc 10 eg)) (if (eq 4 (cdr (assoc 90 eg))) (setpropertyvalue e "Closed" 1) ;else (setpropertyvalue (cdr (assoc -1 (entmod (append (subst '(90 . 4) (assoc 90 eg) (reverse (cdr (reverse eg)))) (list (cons 10 (polar (caddr ptList) (angle (cadr ptList) (car ptList)) (distance (cadr ptList) (car ptList)) );polar );cons );list (list (assoc 210 eg)) );apply );entmod );assoc );cdr "Closed" 1 );setpropertyvalue );if );repeat ;else (prompt "\nNo 3 or 4 segment un-closed polylines were found.") );if (setq ss nil) (prompt "\nLCCLOSE Complete.") (princ) );defun
Best,
~DD
Message 7 of 11
faugustom
CTR works perfectly! Thank you
CTRLINES generated an error, but I'm using polylines, so, it's ok!
Command: CTRLINES
First point>
Second point>
Invalid option keyword.
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Reverse/Undo]:
Thank you again
Message 8 of 11
faugustom
exactly 😉
Message 9 of 11
faugustom
Perfectly!
Thank you!
Message 10 of 11
Kent1Cooper
My guess is that you have PEDITACCEPT set to 1, and this line is the problem:
If the selection involves Lines or Arcs, and PEDITACCEPT is 0, it will ask whether to convert them to Polylines, which is what that "y[es]" answer is for.  If PEDITACCEPT is 1, that question will not be asked, and "y" will be an invalid option.
Try either setting PEDITACCEPT to 0 or removing that "y" entry, and see whether it works.
Kent Cooper, AIA
Message 11 of 11
hak_vz
Thank you @Kent1Cooper.
You have pointed out a potential problem with command pedit, that can often be overlooked.
In case PEDITACCEPT  is set to 0 function CRTLINES is actually better since it work both on lines and lwpolylines. In second step,  function collects all lwpolylines inside previously defined window, either preexisting or converted.
If there is no lines to convert (zero selection set), it continues with lwpolilines.
Miljenko Hatlak
