Cleaning Lisp
Cleaning Lisp
antwanKNH9Z
Observer Observer
Cleaning Lisp
antwanKNH9Z
Observer
Observer
kindly, anyone has a powerful cleaning lisp to do the following all in one go without popup messages asking for inputs or selections?
  1. Purge, -Purge
  2. Audit
  3. Flatten Objects
  4. Overkill
  5. "open for more cleaning options to reduce file size and speed up CAD"
Thank you in advance.
Sea-Haven
Do "Logfileon".
Then do all your commands, try using a '-" in front of the command.
Do "Logfileoff" to stop recording.
Then look at the logfile produced, just use notepad to edit the file, it will be all the command steps needed in your lisp program. The logfile is saved in your temporary directory, "Options" "Files" "Temp directory".
The other way is get two things, the 1st object is called a pencil, the other a piece of paper and write down all you see.
timothy_crouse
Here you go. . .
Best Regards
-Tim C.
antwanKNH9Z
Observer
Observer
Prefer option 1 lol.. Thanks
antwanKNH9Z
Observer
Observer
Great cleaning lisp.. thank you 🙂
timothy_crouse
Nice, Well play'd good man, Well play'd indeed 🙂
