circle to circle dimension only text and line
Gaganpatel
Gaganpatel
  Dear Sir,
I have circle to circle dimension only text & dimension line,
Please help me.
oscardosanjos
can you improve your question for a better understanding of what do you really need?
Gaganpatel
Dear Sir,
Actually we are making assembly and from that assembly we are making part drawing and that drawing we have to fit in A4 size sheet.
Some times the object length around 10Mtr in that case we have stretch my object to the required length and convert that dimension into exploded text.
CADaSchtroumpf
Why you do not use QSELECT with Dimension and Style P.
When select, explode them and apply SCALE with Ref
With this, you don't lost value of the dim text
DGRL
@Gaganpatel
Looking at your drawing I just wonder why don't you use Viewports?
If this was of any help please kudo and/or Accept as Solution
Kind Regards
hak_vz
Best option to your problem is to use viewports and annotative scaling.
If this option is unavailable for you, regarding your current practice, best option would be
to create new  object to fit A4, and not to look reshaped or much elongated, the way you do it now.
Put on "false" dimensions. and override them in one continuous loop.
(defun c:edimtext ( / ent val *error*)
(defun *error* () (setvar cmdecho 1) (princ))
(setvar "cmdecho" 0)
(while
  (setq
    ent (entget(car (entsel "\nSelect dimension object >")))
    val (getstring "\n Override dimension or text >")
    ent (subst  (cons 1  val)(assoc 1 ent) ent)
    ent(entmod ent)
(setvar "cmdecho" 1)
(princ)
Miljenko Hatlak
