Circle Block to Circle Block Dimension Only Text
Gaganpatel
Message 1 of 8
Gaganpatel
Hi every one,
I have circle block to circle block dimension only text auto lisp file.
Please see the example file.
Thanks & Regards
Kalandi Paital
Replies (7)
Message 2 of 8
Gaganpatel
Please help sir
Message 3 of 8
Sorry for any grammatical error, I'm using google to translate.
Could you be more specific in your question?
Júnior Nogueira.
Por favor,  Aceitar como Solução se meu post te ajudar.
Please Accept as Solution if my post helps you.
Message 4 of 8
hak_vz
You have already asked this question before and received answer to it on 15.03.2018.
Use given autolisp code to edit dimensions.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/circle-to-circle-dimension-only-text...
Miljenko Hatlak
Message 5 of 8
marko_ribar
Here you go... Quick and simple...
(defun c:bc2bcdims2txt ( / ss ax ts ip sp revf i e el dl str txts )
  (vl-load-com)
  (prompt "\nSelect circle blocks...")
  (setq ss (ssget '((0 . "INSERT"))))
  (setq ax (entsel "\nPick axis where blocks are aligned - picking near desired start point..."))
  (initget 7)
  (setq ts (getdist "\nPick or specify text size : "))
  (initget 1)
  (setq ip (getpoint "\nPick or specify insertion point of text : "))
  (if (and ss ax ts ip)
    (progn
      (setq sp (vlax-curve-getclosestpointto (car ax) (cadr ax)))
      (if (> (distance sp (vlax-curve-getstartpoint (car ax))) (distance sp (vlax-curve-getendpoint (car ax))))
        (setq revf t)
      (repeat (setq i (sslength ss))
        (setq e (ssname ss (setq i (1- i))))
        (if (< (distance (cdr (assoc 10 (entget e))) (vlax-curve-getclosestpointto (car ax) (cdr (assoc 10 (entget e))))) 0.25)
          (setq el (cons e el))
      (setq el (vl-sort el '(lambda ( a b ) (if revf (> (vlax-curve-getdistatparam (car ax) (vlax-curve-getparamatpoint (car ax) (vlax-curve-getclosestpointto (car ax) (cdr (assoc 10 (entget a)))))) (vlax-curve-getdistatparam (car ax) (vlax-curve-getparamatpoint (car ax) (vlax-curve-getclosestpointto (car ax) (cdr (assoc 10 (entget b))))))) (< (vlax-curve-getdistatparam (car ax) (vlax-curve-getparamatpoint (car ax) (vlax-curve-getclosestpointto (car ax) (cdr (assoc 10 (entget a)))))) (vlax-curve-getdistatparam (car ax) (vlax-curve-getparamatpoint (car ax) (vlax-curve-getclosestpointto (car ax) (cdr (assoc 10 (entget b)))))))))))
      (setq dl (mapcar '(lambda ( a b ) (distance (cdr (assoc 10 (entget a))) (cdr (assoc 10 (entget b))))) el (cdr el)))
      (setq txts (strcat "-" (substr (setq str (apply 'strcat (apply 'append (mapcar '(lambda ( x ) (list (if (< 0.25 (- x (fix x)) 0.75) (strcat (itoa (fix x)) ".5") (rtos x 2 0)) "+")) dl)))) 1 (1- (strlen str))) "-"))
      (vl-cmdf "_.TEXT" "_non" ip ts (cvunit (if revf (angle (vlax-curve-getendpoint (car ax)) (vlax-curve-getstartpoint (car ax))) (angle (vlax-curve-getstartpoint (car ax)) (vlax-curve-getendpoint (car ax)))) "radian" "degree") txts)
  (princ)
HTH., M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 6 of 8
Gaganpatel
Dear Sir,
Please give me salutation for text size default and text place for circle position align.
Message 7 of 8
marko_ribar
Just change (setq ts ... ) and (setq ip ... ) to suit your needs...
For me it's working as it is without any problem... So it is solution at least for me...
Regards, M.R.
Message 8 of 8
Gaganpatel
Dear Sir,
Please help me.
