Check image button mode status
paullimapa
Mentor Mentor
paullimapa
For image buttons in dcl when dialogue box is running is there a way to check the mode status to see if the image button has been “flipped” highlighted or not? Another words has (mode_tile image-button-key 4) been applied to it already so I don’t flip the image button again?
Paul Li
IT Specialist
@The Office
Sea-Haven
You can do calls to defuns in a dcl so I guess could do a check if once on, then stay on, each time you click any image. ie reset a "on" list.
paullimapa
I was hoping there would be a get_attrib function that could give me the current image button status. But definitely adding the image key into a list when flipped and then removing it from the list when unflipped would do the trick. Thanks.
Paul Li
IT Specialist
@The Office
_Tharwat
I do prefer to use an action_tile for each one then I can add as many functions as I want once a user press the button.
