Check if "Purge" is required without purging
Message 1 of 1
Is there a way to recieve information about a model (dwg) being "purgeable"?
I don't have the right to write in the dwg-files since I'm only reviewing them, and having to open each file individually to type "purge" (to see the purge window) is a quite ineffective way of seeing if the model needs/can be purged - I feel.
The output would be some format able to work into an excel sheet (or similar).
Is this possible?
Thanks!
Replies (0)
