Check if cui is loaded LISP
Hello guys
Can anyone send me the Lisp command to check if my menu "TestAPP" is loaded, if yes so unload it.
After that I will load it again.
The reason is, If I make an Update I just want to add the new .cuix File in same path and it should reload CUIX by everytime open AutoCAD.
I currently have this:
(vla-unload (vla-item (vla-get-menugroups (vlax-get-acad-object)) "TestAPP"))
(command "menuload" "C:\\Program Files\\Common Files\\TestAPP\\TestAPP.cuix")
The problem with this code is that if the user has never loaded "TestAPP" CUIX, AutoCAD gives an error that the unloading does not work.
Can anyone help me?
Sea-Haven
Here is a start different method
(setq men (vla-get-menugroups (vlax-get-acad-object)))
(vlax-for meni men
(if (= (vla-get-name meni) "TESTAPP")
(alert "menu found")
(alert "menu not found")
pbejse
Can anyone help me?
Test if the menu is valid before unload/loading
(not
      (vl-catch-all-error-p
	(setq found (vl-catch-all-apply 'vla-item (list men "TestAPP")))
ronjonp
Here's another ( untested ).
(defun c:foo (/ m mg r)
  (setq mg (vla-get-menugroups (vlax-get-acad-object)))
  (setq m "TestAPP")
  (if (= 'vla-object (type (setq r (vl-catch-all-apply 'vla-item (list mg m)))))
    (vla-unload r)
  (command "_.menuload" (strcat "C:\\Program Files\\Common Files\\TestAPP\\" m ".cuix"))
  (princ)
