Changing scale of all entities in multiple .dxfs
spencer.robertsU8DLN
Due to some software limitations, I've been given a large number of .dxf files that were drawn in mm that need to be scaled to inches before being sent to fabrication.
I've gotten as far as iterating through a list of files, and being able to open, save and close each one, however I'm having a stumbling block as to how to change the scale for all entities.
(defun ScaleFiles (files factor / acadApp acadDocs)
  (setq acadApp (vlax-get-acad-object))
  (setq acadDocs (vlax-get-property acadApp 'Documents))
  (mapcar
    '(lambda (fp / newDoc eMin eMax)
      (setq newDoc (vlax-invoke acadDocs 'open fp))
      ;(command "_Scale" "_All" "" "0,0" factor) ;Doesn't work
      (vlax-invoke newDoc 'close ':vlax-true)
    );lambda
    files
  );mapcar
);defun
I've done a bit of digging and found that ObjectDBX has a few limitations:
If the above is true, is it even possible to scale these drawings like this? or would I need to use an alternative solution (like script pro) instead?
Any suggestions would be appreciated.
pendean
Community Legend
Community Legend
DWGUNITS command will reset "units" and rescale your file's content, just follow the prompts.
paullimapa
Just so you know, any conversion whether from Imperial (Ft-Inch) to Metric (mm) or vise a versa will end up with strange dimensions. So a standard 900 wide mm door will end up becoming a non-standard 29.5 wide Ft-Inch door which would typically not be up to code standard.
Paul Li
IT Specialist
@The Office
ronjonp
@spencer.robertsU8DLN
You could use vla-ScaleEntity with ODBX.
Sea-Haven
Be careful using say -dwgunits its appears to be platform dependant it will run with the 5 questions or it can run with 6 as I have just found out, so have gone back to a setvar sequence to avoid this problem. Still checking. As need to work with a client having a mix of platform Acad, Archi, CIV3D etc.
_dwgunits help needed. - AutoCAD Bugs, Error Messages & Quirks - AutoCAD Forums (cadtutor.net)
