Changing multiple mext to match chainage
Message 1 of 8
I am looking for some help in changing multiple mtext on a section profile to match the chainage.
Attached is a screenshot of what I have just now and what I want to achieve. I am looking for some way to automate the function.
Thanks to anyone that can help.
Replies (7)
Message 2 of 8
_gile
You can ude the (free) Increment plugin on Autodesk Apps Store.
It can do this and some more.
A screen cast is comming soon.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
hak_vz
Try this. It creates mtext element at horizontal distance from the origin.
(defun c:chn ( /  )
(setq origin (getpoint "\nSelect origin >")
      textsize (getreal "\n Text size? >")
	(repeat 500
		(setq pt (getpoint "\nSelect chainage point >")
		      di (rtos (-(car pt)(car origin)) 2 2)
		(entmake
			  (list
					  (cons 0 "MTEXT")
					  (cons 100 "AcDbEntity")
					  (cons 8 "0")
					  (cons 100 "AcDbMText")
					  (cons 10 (list (car pt) (- (cadr pt)0.5)))
					  (cons 40 textsize)
					  (cons 71 6)
					  (cons 50 (/ pi 2))
					  (cons 1 di)
Miljenko Hatlak
Message 4 of 8
_gile
Gilles Chanteau
GileCAD
GitHub
Message 5 of 8
ВeekeeCZ
	(repeat 500
		(entmake
Right, why not to use a simple routine, right to for right job...
... but I can imagine that the (while (until user pick another point) (entmake tex)) function would be much suitable and more comfortable to user then your (repeat 500 (in the fact, why 500?)) then need to hit ESC to break the loop.
(while (setq pt (getpoint "\nSelect chainage point >"))
  (entmake ...))
BTW. Very nice tool, @_gile
Message 6 of 8
hak_vz
  (entmake ...))
I agree, WHILE loop would serve better. I typed this code during my 5 min break, that's why it's not edited, variables are all global, it only works in one direction ...... cmdecho on/off is not set, instead of MTEXT plain TEXT would do the trick.....
I prefer to exit commands by hitting ESC. As a old school CAD user I type in majority of commands , and rarely use commands with GUI's. To be shure that I'm out of command I frequently hit ESC key 🙂
Miljenko Hatlak
Message 7 of 8
This is pretty much exactly what I was looking for.
Is there anyway that I could specify the distance and change the style the text comes in?
Message 8 of 8
hak_vz
(defun c:chn ( /  *error* origin textsize textstyle offset pt di decimal_places)
    (defun *error* ()
        (setvar "cmdecho" 1)(princ)
    (setq
        textsize (getreal "\n Text size  >")
        textstyle (getstring "\n Text style def = 'standard'  >" )
        decimal_places (getint "\n Decimal places  def = 2  >")
        offset (getreal "\n Text offset from tickline def = 1  >")
    (if (not (tblsearch "style" textstyle)) (setq textstyle "STANDARD"))
    (if (not textsize) (setq textsize (getvar "textsize")))
    (if (not decimal_places) (setq decimal_places 2))
    (if (not offset) (setq offset 1))
    (setvar "cmdecho" 0)
    (while
              di (rtos (-(car pt)(car origin)) 2 decimal_places)
        (entmake
            (list
                (cons 0 "MTEXT")
                (cons 8 "0")
                (cons 10 (list (car pt) (- (cadr pt) offset)))
                (cons 40 textsize)
                            (cons 7 textstyle)
                (cons 71 6)
                (cons 50 (/ pi 2))
                (cons 1 di)
    (princ)
Miljenko Hatlak
