I have an old command (from when the MTEXT was introduced) which set group 41 to 0 to remove word wrapping if the bounding box was too small for the contents.
Since I switched to AutoCAD 2023 this no longer works - changing DXF group 41 with lisp has no visual effect.
The old "width" property is no longer there, but there's a "defined width" which is read only.
I can only change it by dragging the ruler on the MTEXT editor.
How can achieve this with code in 2023?
