changing LAYMRG prompt default
james.cunninghamPJ6KR
When I am cleaning up floor and site plans that have a multitude of unnecessary {construction} layers (for our layout purposes)
I use LAYMRG to combine layers that have been embedded in blocks.
So when I see 4 different layers for doors or windows, I keep one and merge the remainder to layer ‘0’
{i.e.  our layout drawing backgrounds don’t need to have door pattern layers, door frame layers, door threshold layer, door header layer ad nauseum,  just wastes time to scroll through the list of layers when modifying the device drawing or setting up the plot sheets}
This can be tedious since the Autocad prompting defaults to NO requiring typing in Y to change the answer.
"Do you wish to continue?
    Enter Yes or No to verify that you want to complete the merge operation. "
The default is NO, and want to change that to YES, so I don't have to type in Y everytime.
Any idea where that configuration option would be located?
ВeekeeCZ
It won't by possible. Maybe we could do something about it... (suppress?), but we don't change the default.
BTW do you know that LAYMRG is also accessible from the Layer Manager? I found myself that more convenient for such a job.
ВeekeeCZ
@ВeekeeCZ wrote:
... Maybe we could do something about it... (suppress?)...
This LISP routine runs the -LAYMRG command and when the prompt pop up, the routine gives "YES" for you. So it kinda suppresses the prompt.
(defun c:LMRG nil
  (command "_.-LAYMRG")
  (while (> (getvar 'CMDACTIVE) 0)
    (if (wcmatch (getvar 'LASTPROMPT) "You are about to merge*")
      (command "_Yes")
      (command PAUSE)))
  (princ)
