changing Elevation issue
gwhitcherQ98HZ
gwhitcherQ98HZ
Whenever I use this in a function I get this error:
** Error: ActiveX Server returned the error: unknown name: Elevation **
What am i missing? Is there a better way to do this?
(vlax-map-collection (vla-get-modelspace doc)
'(lambda (object) (if
(and
(/= "AcDbBlockReference" (vla-get-objectname object))
(/= "AcDbMText" (vla-get-objectname object))
(/= "AcDbHatch" (vla-get-objectname object))
(progn
(vla-put-elevation object 0))
paullimapa
easy to find out why by doing the following:
place these 3 object types on your drawing:
Hatch
MText
Block
run this code on each:
(vlax-dump-object (vlax-ename->vla-object (car(entsel))))
If you don't see an Elevation property on the text screen dump, then this line in your code will fail with an error:
Paul Li
IT Specialist
@The Office
john.uhden
@gwhitcherQ98HZ ,
I agree with @paullimapa .
IOW,
You can't change the property of an object if it doesn't have that property.
If you don't know for sure that an object has the target property, then you must "dump" it to find out, or be cautious ahead of time with...
(if (vlax-property-available-p object 'Elevation) ;; then go ahead and change it.
Of the three types of objects you wanted to modify, only the Hatch had an Elevation property.
John F. Uhden
gwhitcherQ98HZ
I was able to get the z value and move the objects from that value to 0.
paullimapa
