Changing Default Hatch Settings
JohnC_ISM
Message 1 of 9
JohnC_ISM
looking to make it so hatch settings are permanently set and dont reset after each hatch. ive attached the pic of what i want to change
draw order - set to send to back
island style - set to ignore
separate hatches - turned on
Replies (8)
Message 2 of 9
_gile
Have a look at these system variables:
HPDRAWORDER = 1
HPISLANDDETECTION = 2
HPSEPARATE = 1
Gilles Chanteau
GileCAD
GitHub
Message 3 of 9
pbejse
Edit: Too slow... 😄
FWIW: You can hover over the item to see what is system variable such as hatch separate hatches
Just make sure Show tooltips is checked on Display/Windows Elements in OPTIONS
Message 4 of 9
JohnC_ISM
this worked. now hopefully they stay at those values. i know its supposed to be system variables but before when i tried to change an option it didnt, and i had to get a lisp written for the acaddoc file. but thank you !
Message 5 of 9
JohnC_ISM
okay so it didnt work. i changed the system variables.
it worked that one time but that was it.
i went back to check the system variables again and it shows NEW VALUE as what i changed it to, but and the CURRENT VALUE still hasnt changed. i set em and clicked okay. im not sure why its not working.
Message 6 of 9
pbejse
Do you mean on existing HATCH entities  prior to setting the new value? Then yes you may have to set it afterwards.
Message 7 of 9
JohnC_ISM
okay so apparently its just not saving the change to the system so when i open back up it goes back to what it was before.
Message 8 of 9
Kent1Cooper
That's right, and Help will tell you all about it for any and all of those System Variables [including whether or not the same is true for all of them -- I didn't investigate], for example:
Kent Cooper, AIA
Message 9 of 9
JohnC_ISM
Oh okay yeah the random target folder that popped up to save worried me I thought I messed something up. Gotit now!!! Thanks.
