Changing annotative scale and scale of viewports
Message 1 of 11
How could i set the annoative scale and scale of all viewports from a drawing, using a code?
Thanks in advance.
Replies (10)
Message 2 of 11
pbejse
Look into vla-put-customscale
Message 3 of 11
and annotative scale can be set with vlax-put-property?
Message 4 of 11
pbejse
Yes. You are referring to a viewport right?
Show us what you have, and we'll point you in the right direction
Message 5 of 11
Yes, i am talking about vports
This is my idea:
 - you specify inside the code the scale and annotative scale
 - the lisp will apply these scales to all layouts and then it will block them
But I dont know how to code for the annotative scale
   (defun c:1 (/ fen n sel tot)
  (vl-load-com)
  (vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
  (if (setq sel (ssget "x" (list (cons 0 "VIEWPORT"))))
    (progn
      (setq n 0 tot 0)
      (while (ssname sel n)
        (if (and (= (logand (cdr (assoc 90 (entget (ssname sel n)))) 16384) 0) (/= (cdr (assoc 69 (entget (ssname sel n)))) 1))
          (progn
            (setq fen (vlax-ename->vla-object (ssname sel n)))
	    (vlax-put-property fen 'CustomScale 0.25) ;; aqui debes poner el factor de escala normal (resultado de 1000/escala deseada)
            (vlax-put-property fen "displaylocked" :vlax-true)
            (setq tot (1+ tot))
        (setq n (1+ n))
      (princ (strcat "\n"  (itoa tot) " VPorts locked )"))
    (princ "\nNO VPorts ! ")
  (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
  (princ)
Message 6 of 11
pbejse
This is my idea:
Are you wanting to select from a list of existing annotative scales?  Then apply the selected scale to all the viewports.
Message 7 of 11
Yes there is a default scale list which you can add more scales (scalelistedit)
and you say to apply the selected scale to all viewports, but, how?
Message 8 of 11
pbejse
@Anonymous wrote:
but, how?
First, collect all existing Annoscale
(setq AnnoscaleList
	(mapcar (function (lambda (scle / ent d)
			    (Setq ent (entget (cdr scle)))
			    (setq d (mapcar '(lambda (as)
						(cdr (assoc as ent))) '(300 140 141)))
			       (list (Car d) (/ (cadr d)(caddr d)))))
		(vl-remove-if-not '(lambda (as)
				     (= 350 (car as)))
				     (dictsearch (namedobjdict) "ACAD_SCALELIST"))
Fill up a list box with that value from the above snippet
(mapcar 'car AnnoscaleList)
After selection, apply the second value based on the selected item
(Cadr (assoc  [selected item]  AnnoscaleList)
then assign the value to selected viewports
(vlax-put-property fen 'CustomScale [ from the snippet above ] )
HTH
Holler if you need help.
Message 9 of 11
Hello
Message 10 of 11
pbejse
@Anonymous wrote:
Hello
You mean you want to be prompted for the scale?
  (if (and
	(setq scale (getint "\nEnter viewport scale to apply: <1/-> "))
and
(vlax-put-property fen 'CustomScale (/ 1.0 scale))
HTH
Message 11 of 11
Hello
(defun c:camesca (/ fen n sel tot)
  (vl-load-com)
    (progn
      (setq n 0 tot 0)
          (progn
		(setq layoutOld (getvar "CTAB"))
			(foreach layoutCrt (layoutlist)
				(setvar "CTAB" layoutCrt)
				(command "_mspace")
				(command "_cannoscale"
				"1:4") ;; aqui se pone la escala anotativa. Debe existir ya en la lista de editatlistaescala
				(command "_pspace")
		(setvar "CTAB" layoutOld)
            (setq tot (1+ tot))
        (setq n (1+ n))
  (princ)
(princ)
