Changing all Text styles to another text style
Can anybody help me with the below code; I'd like to modify this code so that i can create a new text style with Arial Font and then change all text styles in a drawing to that style. Also is there a way that i can put an icon on the toolbar to have this lisp runs every time i push it?
(defun ChangeStyle (strStyle1 strStyle2 / entItem objBlock objDocument objItem )
 (vl-load-com)
 (setq objDocument (vla-get-activedocument (vlax-get-acad-object)))
 (if (and (tblobjname "style" strStyle1)
          (tblobjname "style" strStyle2)
  (vlax-for objBlock (vla-get-blocks objDocument)
   (if (> (vla-get-count objBlock) 0)
    (progn
     (setq objItem (vla-item objBlock 0)
           entItem (vlax-vla-object->ename objItem)
     (while entItem
      (if (and (vlax-property-available-p (setq objItem (vlax-ename->vla-object entItem)) "StyleName")
               (= (strcase (vla-get-stylename objItem)) (strcase strStyle1))
       (vla-put-stylename objItem strStyle2)
      (setq entItem (entnext entItem))
  (princ "\nError check if styles exist: ")
 (vla-regen objDocument 0)
Thanks for your help!
devitg
Please upload your sample.dwg
Here you go @devitg
Thanks.
ronjonp
How about something like this to apply arial.ttf to all styles :).
(defun c:foo (/ d)
  (vlax-for x (vla-get-textstyles (setq d (vla-get-activedocument (vlax-get-acad-object))))
    (vla-put-fontfile x "arial.ttf")
  (vla-regen d 1)
  (princ)
)(vl-load-com)
Am I running this wrong I get a file error.
"Automation Error. Filer error"
devitg
Arial.ttf font file shall be at ACAD font folder. And set to your text style
ronjonp
Try this:
(defun c:foo (/ d ff)
  (if (findfile (setq ff (strcat (getenv "windir") "\\FONTS\\arial.ttf")))
    (progn (vlax-for x (vla-get-textstyles (setq d (vla-get-activedocument (vlax-get-acad-object))))
	     (vla-put-fontfile x ff)
	   (vla-regen d 1)
    (alert (strcat ff " NOT FOUND!"))
  (princ)
(vl-load-com)
