Changing a LISP
Changing a LISP
jeroendewind
Changing a LISP
jeroendewind
Hi all,
Someone here gave me this awesome LISP that I used a lot, but with my latest projects it's becoming kinda useless.
The LISP makes it possible to split a dimension at a given point, but only when the coordination system is set to World.
Is it possible for someone to change it to the same LISP, usable for every UCS?
(defun c:LegLengthMod ( / ss dimobjs)
  ;; codehimbelonga KerryBrown@theSwamp 2010.05.28
  ;; http://www.theswamp.org/index.php?topic=33493.msg389031#msg389031
  (vl-load-com)
  (if (and (setq ss (ssget '((0 . "DIMENSION"))))
           (setq dimobjs (mapcar 'vlax-ename->vla-object
                                 (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
    (foreach dim dimobjs
      (vla-put-extlinefixedlensuppress dim :vlax-true)
      (vla-put-extlinefixedlen dim (* 2 (vla-get-textheight dim)))
  (princ)
(defun c:SD (/ sel newpt ent edata elist)
  (if (and (setq sel (entsel "\nSelect Dimension to Split."))
           (setq newpt (getpoint "\Select new Dim Point"))
    (progn (setq ent   (car sel)
                 edata (entget ent)
                 elist (vl-remove-if
                         '(lambda (pair)
                            (member (car pair)
                                    (list -1 2 5 102 310 300 330 331 340 350 360 410)
                         edata
           (entmod (subst (cons 14 newpt) (assoc 14 elist) edata))
           (entmakex (subst (cons 13 newpt) (assoc 13 elist) elist))
  (princ)
_gile
"Someone" is @kerry_w_brown as you can see in the comments.
Replace the c:SD defun with:
    (progn (setq newpt (trans newpt 1 0)
                 ent   (car sel)
                 edata (entget ent)
                 elist (vl-remove-if
                         '(lambda (pair)
                            (member (car pair)
                         edata
  (princ)
Gilles Chanteau
GileCAD
GitHub
jeroendewind
Thanks a lot!
kerry_w_brown
Thanks @_gile
Funny how code written as 'proof of concept code' survives.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
