Change viewports Layer
My_Civil_3D
My_Civil_3D
Hi guys i am having a problem with my code. i am trying to change the layer of the viewports in my sheet, it works well but at the end i want to change the layer back to the last layer it was on but it doesnt want to. not sure why
(defun c:C_CVL (/ selViewports OldLayer)
(setq OldLayer(Getvar "Clayer"))
(setq selViewports (ssget "X" '((0 . "VIEWPORT"))))
(if(tblsearch "LAYER" ".VIEWPORT")
(setvar "Clayer" ".VIEWPORT")
(command "-layer" "m" ".VIEWPORT" "c" 150 "" "P" "N" """"))
(command "CHPROP" sel1 "" "LAYER" ".VIEWPORT" "")
(setvar "Clayer" OldLayer )
(princ)
Civil 3D Certified Professional
komondormrex
hey, there is no sel1 selection set
	(setq OldLayer (Getvar "Clayer"))
	(if (not (tblsearch "LAYER" ".VIEWPORT"))
	(command "CHPROP" selViewports "" "LAYER" ".VIEWPORT" "")
	(princ)
My_Civil_3D
Problem fixed thank you
(defun c:C_CVL (/ sel1 OldLayer)
(setq sel1 (ssget "X" '((0 . "VIEWPORT"))))
(setvar "Clayer" OldLayer)
(princ)
ronjonp
@My_Civil_3D
Here's another way to do it without messing with the current layer.
(defun c:c_cvl (/ l n s)
  (cond	((setq s (ssget "_X" '((0 . "VIEWPORT"))))
	 (setq n ".VIEWPORT")
	 (setq l (vla-add (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) n))
	 (vla-put-color l 150)
	 (foreach e (mapcar 'cadr (ssnamex s)) (vla-put-layer (vlax-ename->vla-object e) n))
  (princ)
Kent1Cooper
How about simply checking whether the ".VIEWPORT" Layer exists, and if it does, LAYMRG the "VIEWPORT" Layer into it, and if it doesn't, just RENAME "VIEWPORT" to add the period prefix?  No dealing with the current Layer, no object selection involved, etc.
Kent Cooper, AIA
