Change the value of -DWGUNITS without command
FELIXJMELO
FELIXJMELO
Change the value of -DWGUNITS without command?
paullimapa
Don’t think there’s another option other than the command
Paul Li
IT Specialist
@The Office
TomBeauford
You can change unit values by modifying the system variables for each value in acaddoc.lsp.
(if (/= (getvar 'angbase) 0)(progn(setvar 'angbase 0)(princ "\nSet base angle to 0 (East). ANGBASE")))
(if (/= (getvar 'angdir) 0)(progn(setvar 'angdir 0)(princ "\nSet angle direction to counterclockwise. ANGDIR")))
(if (/= (getvar 'aunits) 4)(progn(setvar 'aunits 4)(princ "\nSurvey units. AUNITS")))
(if (/= (getvar 'auprec) 3)(progn(setvar 'auprec 3)(princ "\nSet angle precision to ddd°-mm'-ss\". AUPREC")))
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
ec-cad
At Command Prompt, type in UNITS<enter>
You can set the dwgunits there.
OR
You can use the Command "_-dwgunits" ... in your acaddoc.lsp file (if not found, make one with Notepad),
and put this in there:  (command "_-dwgunits" "3" "2" "4" "Yes" "Yes")(graphscr)
You will want to review the 3, 2, 4 settings.
I tried it at the command prompt, it does the job.
ECCAD
Sea-Haven
ec-cad
THx.
I edited the previous posting.
ECCAD
MICROCADDAER6
If you change -DWGUNITS from 3 to 6, AutoCAD displays the message below and asks the user for confirmations, which in a professional program is not very elegant.
** WARNING: you have changed the unit for this drawing database. **
** All new objects will be drawn according to the new unit, but **
** existing objects will not change size unless you specifically **
** ask to have automatic scaling occur. **
nil
Scale objects in current drawing to reflect change in units? [Yes/No] <Yes>:
Include objects in Paper Space? [Yes/No] <Yes>:
