Change the attribute Tag
Henrik_Lo
Henrik_Lo
Hi
Dose somebody having a lisp code dos following.
Insert a block multiple times, and change the attribute Tag with defriend numbers each time a new block is insert.
I can do most of the code, but can’t remember how to change attribute tag.
Regards
Henrik
ВeekeeCZ
Really change attribute tag or rather its value? If the latter then
(setpropertyvalue ent "tag" "value")
Henrik_Lo
Hi
sorry, it is the value i need change.
Regards
Henrik
pbejse
Yeah, odd isn't it?
EDIT: oops, the OP already replied to it. 😁
So, every instance of block that you insert, follow it up with what @ВeekeeCZ said at post #2
Easy peasy
Henrik_Lo
Hi
This seem to work for me, fantastic thangs
Regards
Henrik
Sea-Haven
A good idea is find all the blocks of a name  and get the last number then you don't have 2 the same. Handy when you stop start inserting.
Pretty sure Lee-mac has a autonumbering which updates if you remove a block by renumbering all.
