Change Text Style Definitions
CNinBC
CNinBC
Hi Everyone,
one of our client asks us to provide drawing in pdf format with searchable text function, we haveto swap all the text style definition(except for style "Standard" and "Roadname") to use "Arial Narrow.ttf" and change the width factor to 1.
I found a code from https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-change-text-style-font-file-..., and tried to modify it. but it comes up with error message saying " error: no function definition: nil"
I couldn't figure out what i did wrong, any suggestion? Thanks.
(defun c:txt2ttf (/ DOC FNTPTH STY )
  (vl-load-com)
  (setq	doc (vla-get-activedocument
	      (vlax-get-acad-object)
  (setq FntPth (findfile "C:\\Windows\\Fonts\\arialn.ttf"))
  (setq sty (vla-get-textstyles doc))
  (vlax-for s sty
	(setq sname (vla-get-name s))
	(if (/= sname "Standard")
			(vla-put-fontfile s FntPth)
			(vla-put-width s 1.0)
;;			(print sname)
;;		(print sname)
  (if (ssget "x" '((0 . "text")))
 	(vlax-for n	(vla-get-activeselectionset doc)
  (vla-regen doc acAllViewports)
  (princ)
You are missing a progn
  (vl-load-com)
  (vlax-for s sty
		(progn ; this was missing
;;			(print sname)
;;		(print sname)
  (princ)
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
dbhunia
In your code there two modifications needed ............ go through the below code.
(vl-load-com)
(vlax-for s sty
(if (/= sname "Standard" "sections") ; Need to Change this line
(progn ; Add this
;; (print sname)
;; (print sname)
(if (ssget "x" '((0 . "TEXT")))
(princ)
But in my system the above code does not changing the "Width Factor", if this happens with you then go through the attached code.
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
dbhunia
Sorry I forgot to change the variables....
The modified codes are..
First----
(vl-load-com)
(vlax-for s sty
(if (/= sname "Standard" "Roadname")
(progn
(princ)
Second------
(vl-load-com)
(vlax-for s sty
(progn
(Width_Factor)
(princ)
(defun Width_Factor ()
(if (Setq selectionset (ssget "x" '((0 . "TEXT"))))
(repeat (setq N (sslength selectionset))
(setq Data (ssname selectionset (setq N (- N 1))))
(setq EntityData (entget Data))
(setq Text_Style (cdr (assoc 7 EntityData)))
(if (/= Text_Style "Standard")
(if (/= Text_Style "Roadname")
(setq EntityData (subst (cons 41 1.0)(assoc 41 EntityData)EntityData))
(entmod EntityData)
Debashis Bhunia
CNinBC
for some reason, the (/= sname "Standard" "Roadname") doesn't work, I have to use  (and (/= sname "Standard") (/= sname  "Roadname") )
