Change Test Style,"Justification" to Center , height in Block Tag
skchui6159
skchui6159
Anyone know how to change the "Test Style" and "Justification" to Center , height for Specific Tag name like "SIGNED" in a Block using Lisp?
Moshe-A
@skchui6159 ,
Can you tell us how many times this specific "SIGNED" tag exists in your title block?
Moshe
skchui6159
@Moshe-A All same tag name change are OK. Like "SIGNED", "GSTDWGNO".
Reply "SIGNED" tag exists 5 times.😅
Moshe-A
@skchui6159 ,
Although you can define a block with duplicate tag names it is wrong. so i suggest you make each of them unique name.
and explore BATTMAN (block attribute manager) command and see if it can do what you are after.
Moshe
skchui6159
@Moshe-A if just change the "Test Style" to "Standard" and "Justification" to Center in tag only? Because I have many dwgs need to do... Can vla-put can do that? I can not find the active x.
skchui6159
@Moshe-A I have updated the attachment for the duplicate tag names issue.
skchui6159
@Moshe-A  I know how to do it. Thank you very much!
