Change system variable, offset, change system variable back
Message 1 of 32
I'm currently trying to write what I think would be a very simple lisp routine. Typically, my OFFSETGAPTYPE system variable is set to 0. On occasion I want to show a buffer around an object which is better shown by changing OFFSETGAPTYPE to 1 and then using the OFFSET command.
I'd like to write a routine called BUFFER that will change OFFSETGAPTYPE to 1, allow me to run the OFFSET command, then change OFFSETGAPTYPE back to 0. Below is what I have at the moment. The script is changing the variable to 1, allowing me to offset whichever objects but after I hit enter to end the offset command it doesn't change the variable back to 0. In other words, it appears that anything after the offset command isn't being executed.
(defun c:buffer()
(setvar "offsetgaptype" 1)
(command "offset")
(setvar "offsetgaptype" 0)
(princ)
Any help is greatly appreciated!
Accepted solutions (3)
Replies (31)
Message 21 of 32
Ranjit_Singh
@ВeekeeCZ wrote:
My conclusion is that this is working on 2015+ versions (except Kent's).
I agree. Is Autodesk making such unpredictable products that produce random errors across different machines? I don't think so. Something is happening with user settings or how they are executing the code. That's exactly why I requested a screencast (which I am pretty sure we will not be receiving).
I have tested on 2015, 2017, OP has tested on 2018; and thanks again @ВeekeeCZ for your testing on different version including 2012. Code works on all those machines (except 2012). So I will be seriously shocked if it didn't work on 2016 without user manipulation.
As far as command-s and command goes, their choice depends on the code. In the above c:Buffer code command-s is ideal since there is such minimal code to work with. Let me explain. (Below applies to machines running AutoCAD 2015 and up)
See below
As you can see qleader starts, document evaluator is looking still for arguments, it encounters pline command but this isn't a valid argument for qleader and so is ignored and the final line is printed and now qleader command proceeds. Important thing to note is that LISP code did not halt for command to finish. Now try below.code_pauses_for_command-s.gif
As you can see the code beautifully waits for each command-s to complete and moves on to next line, and while in the actual command all options are allowed. This is explained by AutoCAD help statement "The command that is being executed must be started and completed in the same command-s function." which some of us have a hard time interpreting. Let's read in entirety The "-s" suffix stands for "subroutine" execution of the supplied command tokens. In this form, AutoCAD is directly called from AutoLISP, processes the supplied command tokens in a temporary command processor distinct from the main document command processor, and then returns, thus terminating the temporary command processor. The command that is being executed must be started and completed in the same command-s function. That's the reason why every command-s is finished before moving on to the next command. Thus explaining why c:Buffer works everytime in re-setting the offsetgaptype variable.
What is this temporary command processor? Let's see below by combining command-s and command.
Again LISP code is paused nicely for command-s to finish and then goes to polyline command but this time does not pause (that's how command works), and prints the line and continues with the pline command. Clearly shows the difference between command-s and command.
Finally, try below but first save anything you need to. Below will successfully enter the temporary command processor through the document processor and freeze acad.command-s_follows_command.gif
The above is just my understanding based on the help document available here.
I am having a hard time getting hold of 2016 trial version s0 I am still requesting other users to test the code on 2016 and report. I would definitely like to know if 2016 is such a broken piece of software, OR user manipulation was involved to mislead all the other community members.
Message 22 of 32
ActivistInvestor
@ВeekeeCZ wrote:
The both examples works for me as shown on the screencast.
To @john.uhden
See THIS. (command-s) came up wih ACAD 2012 and then the singnificant change in *error* handling came up with 2015.
The behavior of command-s in pre-AutoCAD 2015 releases depends on NEXTFIBERWORLD. In 2015 or later, the behavior should be the same as if you had issued NEXTFIBERWORLD = 0 in older releases.
Message 23 of 32
Ranjit_Singh
@ActivistInvestor wrote:
..........In 2015 or later, the behavior should be the same as if you had issued NEXTFIBERWORLD = 0 in older releases.
Thanks @ActivistInvestor for sharing that information. Below is a little test with the c:Buffer code with NEXTFIBERWORLD set to ON and OFF on AutoCAD 2015.NFW_on_off.gif
You can see that in both the cases the code works fine. I am having a hard time with the screenshot in Post#18. How does the command-s fail without some user manipulation of the offset command. I can present an example here of how one can get that screenshot.offset_manipulated.gif
All I am trying to say is intentionally/ unintentionally the offset command has to be manipulated to throw that error. There are no other elements in that command-s line of below code that can cause its failure?
(defun c:buffer()
(command-s "offset") ; no tokens passed, so command name itself is source of error
(princ)
Message 24 of 32
ActivistInvestor
(defun c:buffer()
(princ)
I'll refer you to the migration guide for the underlying native functions (acedCmdS() and acedCommandS()), as they are much more detailed. To summarize, these two functions (which are what the (command-s) function call) require that all of the input required to complete the command and return AutoCAD to the Command: prompt be provided in the call. How individual commands behave when that requirement is not met could vary by command, and I wouldn't expect all of that behavior to be documented, so I guess that is a good reason why one should adhere to that requirement.
Message 25 of 32
cadffm
@Ranjid.Singh
You can't test NextFiberWorld in this way.
a) MS Fiber is not used by Version 2015 and younger
only the variable exist for compatibility.
b) If you want to try it in older Versions, you have to set the Variable and RESTART Acad.
Acad Re-Start with Fiber enable/disable how Variable was set at last.
Tomorrow i will read this Thread again.
In hurry (2:18AM) the Buffer should work with 2016 and a new Standard Profile (without any loaded other stuff and redefined things)
But tomorrow is also a day, cu
Sebastian
Message 26 of 32
Kent1Cooper
.... OR user manipulation was involved to mislead all the other community members.
It's hard to know how to respond to such a statement, except perhaps to suggest that any notion that I would participate here with any purpose to mislead anyone is easily enough refuted by directing you to:
  Top Solution Authors / View All / All Time
[Let's see -- yes, I'm going to boast a little -- if you manage to rack up 10 more Accepted Solutions than I do every month  on average (once in a while you do), you'll catch up to me in about 5 years.]
But I figured out what the difference is.  You may choose to consider it "user manipulation," but I consider it "functional enhancement."  I've had it in place long enough that it's just background for me by now, so it took me a while to realize.  It's not the difference between  (command)  and  (command-s), nor about whether there is an *error* handler defined, either inside or external to any command definition, but the key is the difference between
and
    (command-s "_.offset")
[or the equivalent  (command-s "._offset")  -- either order of underscore and period/decimal works, as it would also in English versions without the underscore character].
I have an enhanced definition of the OFFSET command, in a routine which Undefines the original first.  The enhanced version allows changing the Offset distance without exiting the command, including changing between a numerical distance and the Through option.  You can try it out -- it's available here.  It's because of that Undefinition that I need the period/decimal prefix on the command name in order for the BUFFER command in this thread to work, and it does  work when I add that.  OFFSET is the only  command I have "replaced" in such a way, so if this thread had involved any other command, there would have been no issue.
I notice that in your screencast examples in Post 21, you do include the  ._  prefix on command names.  If that had been included in Post 3, it would have worked for me all along, but it wasn't in the OP's original, and neither you nor I thought to add it in our suggested alterations.
When I first started getting into (defun)ing custom commands, I was using Architectural Desktop, which similarly Undefined the LAYER command and made its own specialized version.  That meant that  (command "layer")  caused an unknown-command error, and anything I did involving LAYER in a (command) function had to be done with the period/decimal prefix.  Since then, I've always included that, as well as the underscore because of the international reach of these Forums, in any kind of custom command definition.
Kent Cooper, AIA
Message 27 of 32
Ranjit_Singh
Kent1Cooper wrote Top Solution Authors / View All / All Time
[Let's see -- yes, I'm going to boast a little -- if you manage to rack up 10 more Accepted Solutions than I do every month  on average (once in a while you do), you'll catch up to me in about 5 years.] p>
But I figured out what the difference is.  You may choose to consider it "user manipulation," but I consider it "functional enhancement............
Sure you have enhanced version of every single command. It took you 96 hrs to remember that? Your memory cells are pretty weak for a top solution AuthorSmiley Wink it's kind of hard to believe, if not impossible, that all the time while you implied that the error had something to do with command-s or AutoCAD 2016 or that I had a manipulated global error trap, it never crossed your mind that you had modified offset command?
OR maybe it was after Post #23 (the offset command has to be manipulated to throw that error. There are no other elements in that command-s line of below code that can cause its failure?)  and @ВeekeeCZ and @cadffm also suggesting that 2016 should work, that you realized there was no way out but to simply accept.
As far as ..........if you manage to rack up 10 more Accepted Solutions than I do every month  on average (once in a while you do), you'll catch up to me in about 5 years....
seriously? That just documents your sorry state. There are people here like myself who are learners (see this) and people like us grow. It's only people who are full of it, never learn and never grow. Misleading 100's of other community members to feed your own false belief "Top Solution Authors / View All / All Time" is not only pathetic but also unethical. You remind me of A few good men.
Ron: Did you manipulate offset? You don't have to answer that. I will answer that for you. See post 23.
Ken: You want answers?
Ron: I think I'm entitled!
Ken: Son, we live in a world that has a wall... and I am the top Solution author sitting on top of that wall.
Ron: I want the truth! Did you manipulate offset?
Ken: I did the job
Ken: You're god#@&*ed right I did!
Ron: I suggest the members be dismissed.
Message 28 of 32
john.uhden
Easy now, Ranjit.  I think he meant to write "dysfunctional entrenchment."
John F. Uhden
Message 29 of 32
Ranjit_Singh
Precisely.
Message 30 of 32
dbroad
Without stirring hurt feelings, I was out of town when this thread was going on, enjoying sun and fun at the beach with family.  I did test @Ranjit_Singh's version with AutoCAD 2016 and 2017 and it worked without problems but it would have been better to have
(defun c:buffer()
(setvar "_offsetgaptype" 1)
(setvar "_offsetgaptype" 0)
(princ)
for international use and to ensure that command redefinition doesn't cause problems.  I often forget that myself.
I was very interested in the behavior of command-s to allow user interaction without the pause or by looping and had assumed that all command data must be fed with the command call. Thanks for bringing that to our attention.  Feeding the start of the command/response data and letting the user interact in the AutoCAD subcommand environment greatly simplifies this. This opens up new uses for command-s other than in the error handler.
Thanks to ActivistInvestor for the nextfiberworld info.  On 2017, that variable returns: Unknown command "NEXTFIBERWORLD", although it still appears in the registry.
Architect, Registered NC, VA, SC, & GA.
Message 31 of 32
cadffm
@Anonymous
NEXTFIBERWORLD is (only) a system variable, there is no command defined for.
Sebastian
Message 32 of 32
dbroad
Yes. I knew that. I was just reporting the response with AutoCAD 2017.  Most AutoCAD variables can be set by entering their name at the command line.  In AutoCAD 2017, it is nothing as far as I can tell.  It exists only in the registry and in AutoLISP setvar/getvar expressions for backward compatibility.  Here is the response to setvar at the command line:
Command: SETVAR
Enter variable name or [?]: nextfiberworld
Unknown variable name. Type SETVAR ? for a list of variables.
