Change selected dims to new dimstyle
etilley327KA
etilley327KA
How do I fix this to change the dimstyle of the selected dims?
(defun c:TEST (/ dimlst doc ss newDimStyle)
  (vl-load-com)
  (setq dimlst "ARCH DIM")
  (setq newDimStyle nil) ; Initialize newDimStyle to nil
  (vlax-for dim (vla-get-Dimstyles
                  (setq doc
                        (vla-get-ActiveDocument
                          (vlax-get-acad-object))))
    (if (equal (strcase (vla-get-Name dim)) (strcase dimlst))
        (setq newDimStyle dim) ; Set newDimStyle if a match is found
  (if newDimStyle
      (if (setq ss (ssget '((0 . "DIMENSION"))))
          (progn
            (repeat (sslength ss)
              (setq entity (ssname ss (setq i (1- i))))
              (vl-catch-all-apply
               '(lambda ()
                  (vla-put-Dimstyle
                   (vlax-ename->vla-object entity)
                   newDimStyle)
  (princ)
Kent1Cooper
          (progn
I'm not sure this by itself will cover everything, but at least:
  (repeat (setq i (sslength ss))
Kent Cooper, AIA
ronjonp
@etilley327KA  VLA-PUT-DIMSTYLE is not a function. Try: vla-put-StyleName
*You really don't need code for this .. select your dimensions and then change the style name in the properties palette.
Sea-Haven
Like ronjonp use this to get properties and correct name. Its one of those must have tools.
; StyleName = "Annotative"
