change scale after export layout
mohamad-alimam
mohamad-alimam
hello
I use this forum to export the all layout from one file to multiple dwg files each layout will open in different dwg file the problem is when it opens the scale be the same layout scale and i want to stay the same old dwg file scale.
(defun c:exportlayoutinoneclick (/ base lst old_dia)
(setq old_dia (getvar 'filedia))
(setvar 'filedia 0)
(setq lst (layoutlist))
(foreach l lst
(command "_.ctab" l "exportlayout" (strcat (getvar 'dwgprefix) l))
(setvar 'filedia old_dia)
(princ)
new file
after exportafter export
original file
original  fileoriginal file
pbejse
@mohamad-alimam wrote:
hello
Question: Are you using annotative blocks, Annotations and dimensions?
mohamad-alimam
actually I don't use  them, but if it will help me to make it right I can make change
