Change multiple values within a block by same amount
Morning,
Well I didn't know this place existed!!
So essentially I was wondering if there is a shortcut or LISP that would enable me to change multiple values by the same amount.
The example is I want to drop a site by say 300mm therefore I want 100 values to drop by 0.3. I am trying to avoid doing this manually. I do want to be able to select the values to change, as not all will change, ie tie in points. Does anybody have any advice for me.
I have attached a dwg of the block.
Thanks in advance.
3wood
You can try ALTEXT.
hak_vz
@3wood
Will your programs make changes in case where some of @Anonymous  elevations have value like "102.5x" and other don't? Apply your code on whole sample and check left side where you can value like this.
Miljenko Hatlak
3wood
Yes it works for a format as "102.5x".
hak_vz
@3wood
I asked this because I started writing a code after his request on Autocad forum. Since your solution works and OP is satisfied I don't have reasons to continue.
Miljenko Hatlak
