Change layer color
Change layer color
Oh_Snap!
Change layer color
Oh_Snap!
I've been using this lisp I found somewhere on the internet to change a layer color by picking an object on the layer and the color dialog appears and I select new color.  This dialog only has index colors though. Does anyone know if this could be modified to also include True Colors?
(defun C:xlc (/ lay col)
  (setq
    lay (cdr (assoc 8 (entget (car (nentsel "\nObject on Layer to assign color to: ")))))
    col (acad_colordlg (cdr (assoc 62 (tblsearch "layer" lay))) nil)
  (command "_.layer" "_color" col lay "")
  (princ)
Kent1Cooper
  col (acad_truecolordlg (assoc 62 (tblsearch "layer" lay)) nil (assoc 62 (tblsearch "layer" lay)))
EDIT:  But using  what that returns is another matter....  It won't work to just substitute that line.  I'll have to think about that one.  [And I didn't replace my trial "0" layer name with 'lay' in both places -- fixed now.]
Further EDIT:  Minimally tested:
  (setq
  ); setq
  (entmod (append (entget (tblobjname "layer" lay)) col))
  (princ)
); defun
Kent Cooper, AIA
ronjonp
Try this:
(defun c:clc (/ c d e n)
  ;; RJP » 2019-03-19
  ;; Set layer color by pick
  (or (getenv "clc") (setenv "clc" "(62 . 1)"))
  (cond	((setq c (acad_truecolordlg (read (getenv "clc"))))
	 (setenv "clc" (vl-prin1-to-string (last c)))
	 (setq d (vla-get-activedocument (vlax-get-acad-object)))
	 (while	(setq e (car (nentsel "\nSelect entity to change layer color: ")))
	   (entmod (append (entget (tblobjname "layer" (cdr (assoc 8 (entget e))))) c))
	   (vla-regen d acactiveviewport)
  (princ)
(vl-load-com)
Oh_Snap!
That works great!  Thank you Kent.
Oh_Snap!
This also works. Thank you.
ronjonp
@Oh_Snap!
You might give my code a try .. it has quite a bit more error checking and will remember your last color used 😉
*EDIT .. you did try it! 🙂
York13
Is there a way to also have this LISP work with non-xrefed objects too?
Edit: Nevermind.  It appears to work just fine. Thanks.
Double Edit: Now I keep receiving an error Application ERROR: Bad arguments.
