Change Enterprise CUI file path
BrianHailey
Mentor Mentor
BrianHailey
Well, apparently, I sent out my profile to all my users with the Main Customization File and the Enterprise Customization file paths switch. I would like to switch them back using a lisp but what I'm doing doesn't seem to work.
If I use:
(defun c:setpath ()
  (vl-load-com)
  (setq	acadObject  (vlax-get-acad-object)
	prefObject  (vlax-get-property acadobject 'Preferences)
	filesOBject (vlax-get-property prefObject 'Files)
  (vlax-put-property filesObject 'SupportPath "C:\\temp")
it sets the support path just fine. However, if I use:
(defun c:setpath ()
  (vl-load-com)
  (vlax-put-property filesObject 'EnterpriseMenuFile "C:\\temp")
I get the following error: error: Automation Error. Error setting preference property
Any idea on what I'm doing wrong?
Thanks!
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
ronjonp
I think it's readonly ... try this instead: (setenv "EnterpriseMenuFile" "C:\\Temp")
Not much for reference...
BrianHailey
I appreciate the idea but that doesn't seem to work either.
I'm brand new to visual lisp, just following some tutorials and saw that "EnterpriseMenuFile" was listed in the VLIDE so I assumed I could change it. Interestingly enough, "(vlax-get-property filesObject 'EnterpriseMenuFile)" works just fine.
I tried the (setenv "EnterpriseMenuFile" "C:\\temp") but that doesn't change the path in my profile, but that variable has changed. If I do a (getenv "EnterpriseMenuFile"), it reports back "C:\\temp" but the (vlax-get-property filesObject 'EnterpriseMenuFile) still returns the old value and that's what's being displayed in the options.
Any other ideas on how to change this path? My next step is to create a new profile and push that out to all my users but I would really rather avoid that.
GEI Consultants
My Civil 3D Blog
ronjonp
@BrianHailey
You might try restarting CAD then check the value. Sometimes that's needed when writing to the registry.
I just tried to replicate what you described and cannot .. even without a restart of CAD.
BrianHailey
I'm a bit embarrassed. In my testing, I was setting the path to a folder, and not to a specific .cuix file. When I chose a file instead of a folder, the vlax-... works. I appreciate your help and I apologize for wasting your time.
GEI Consultants
My Civil 3D Blog
ronjonp
No worries .. glad you got it sorted.
You could probably use something as simple as this:
(if (findfile "C:\\Temp\\file.cuix")
  (setenv "EnterpriseMenuFile" "C:\\Temp\\file.cuix")
  (alert "ENTERPRISE CUIX FILE NOT FOUND!")
Sea-Haven
Not cui but support path.
(setq *files*  (vla-get-files  (vla-get-preferences (vlax-get-Acad-object))))
(setq paths (vla-get-SupportPath *files*))
(vla-put-SupportPath *files* (strcat "C:\\CAD-TOOLS\\SLIDES;C:\\CAD-TOOLS\\IMAGES;C:\\CAD-TOOLS;" paths))
(if  (> (vl-string-search  "BricsCAD" (getvar 'acadver)) 0)
(princ "Bricscad not found")
(progn
(setq oldtrust (getvar 'trustedpaths))
(if (wcmatch  oldtrust "*XXX*")
(princ)
(setvar 'trustedpaths (strcat oldtrust ";" "c:\\CAD-TOOLS"))
(command "workspace" "save" "" "y")
(alert "\nSupport and trusted paths added")
