Change color of Entity & Blocks [Modification on lisp]
Yamishon_Noah
Message 1 of 9
Yamishon_Noah
I have below lisp which is now converting selected entity or block color to specified.
I want to change it as multi select either entity or block in place of one by one.
Seeking expert help.
Yomishon
(defun c:blcc () (pl:block-color) (princ))
(defun c:encc () (pl:block-ent-color) (princ))
(vl-load-com)
(defun pl:block-ent-color (/ adoc blocks color ent lays)
(setq adoc (vla-get-activedocument (vlax-get-acad-object))
lays (vla-get-layers adoc)
color (acad_colordlg 256)
(if color
(progn (setvar "errno" 0)
(vla-startundomark adoc)
(while (and (not (vl-catch-all-error-p
(setq ent (vl-catch-all-apply
(function nentsel)
'("\nSelect entity <Exit>:")
(/= 52 (getvar "errno"))
(if ent
(progn (setq ent (vlax-ename->vla-object (car ent))
lay (vla-item lays (vla-get-layer ent))
(if (= (vla-get-lock lay) :vlax-true)
(progn (setq layloc (cons lay layloc))
(vla-put-lock lay :vlax-false)
(vl-catch-all-apply (function vla-put-color) (list ent color))
(vla-regen adoc acallviewports)
(princ "\nNothing selection! Try again.")
(foreach i layloc (vla-put-lock i :vlax-true))
(vla-endundomark adoc)
(princ)
(defun pl:block-color (/ adoc blocks color ins lays)
blocks (vla-get-blocks adoc)
(if color
(setq ins (vl-catch-all-apply
(function entsel)
'("\nSelect block <Exit>:")
(if ins
(progn (setq ins (vlax-ename->vla-object (car ins)))
(if (= (vla-get-objectname ins) "AcDbBlockReference")
(if (vlax-property-available-p ins 'path)
(princ "\nThis is external reference! Try pick other.")
(progn (_pl:block-color blocks ins color lays)
(princ "\nThis isn't block! Try pick other.")
(princ)
(defun _pl:block-color (blocks ins color lays / lay layfrz layloc)
(vlax-for e (vla-item blocks (vla-get-name ins))
(setq lay (vla-item lays (vla-get-layer e)))
(if (= (vla-get-freeze lay) :vlax-true)
(progn (setq layfrz (cons lay layfrz)) (vla-put-freeze lay :vlax-false))
(progn (setq layloc (cons lay layloc)) (vla-put-lock lay :vlax-false))
(vl-catch-all-apply (function vla-put-color) (list e color))
(if (and (= (vla-get-objectname e) "AcDbBlockReference")
(not (vlax-property-available-p e 'path))
(_pl:block-color blocks e color lays)
(foreach i layfrz (vla-put-freeze i :vlax-true))
(progn
(princ "\BLCC - Changes color of the chosen blocks")
(princ "\nENCC - Changes color of the chosen objects (may be element of the block)")
(princ))
Replies (8)
Message 2 of 9
m_badran
What about change inside block to layer 0 and select what ever you need to color which you desire.
HTH
Message 3 of 9
Yamishon_Noah
Hello HTH,
That will not be a solution, Actually I dont want to change its layer, only color needs to be changed.
and I have many blocks in drawing.
What I want is Just execute command and select multiple utilities in CAD and change color simply.
Thanks for your reply.
Yamishon
Message 4 of 9
dbhunia
For BLCC try this.....
(defun pl:block-color (/ adoc blocks color ins lays ss)
(if color
	(while (and (setq ss (ssget '((0 . "INSERT"))))
	       (foreach ins (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
			(progn (setq ins (vlax-ename->vla-object ins))
				;(if (= (vla-get-objectname ins) "AcDbBlockReference")
					;(princ "\nThis isn't block! Try pick other.")
			;(princ "\nNothing selection! Try again.")
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 5 of 9
Yamishon_Noah
Hi Expert Debashis Bhunia..
Awesome work..! Thank you.
It converts all selected block to selected color but its not converting dimension color within the block.!
Can you help with this?
Yamishon
Message 6 of 9
Yamishon_Noah
For an entity conversion found below code
But it is not converting dimensions...
Can anyone modify code/adding dimension property also in this code please?
Yamishon
(defun c:Ch_Color (/ clr i ss ent elst)
 (vl-load-com)
 (if (and (setq clr     (acad_colordlg 0))
          (setq i -1 ss (ssget "_:L")))
   (while (setq ent (ssname ss (setq i (1+ i))))
     (setq elst
       (vl-remove-if
         (function
           (lambda (x)
             (vl-position (car x) '(62 420)))) (entget ent)))
     (entmod (append elst (list (cons 62 clr))))))
 (princ ))
Message 7 of 9
dbhunia
Both are working for me (dimensions color change)............ can you post a drawing............
Debashis Bhunia
Message 8 of 9
Yamishon_Noah
Here you go drawing and lisp I used..
Yamishon
Message 9 of 9
Yamishon_Noah
Can anybody help me to complete this?
Yamishon
