Change attribute values in DWG files
Message 1 of 9
What about block attributes within the dwg's?  Not the windows/ntfs file attributes - Block Attributes
e.g. when you double-click the title block, it opens a dialog called "Enhanced Attribute Editor" - This is what needs to be adjusted, along with maybe some other block attributes, and the filenames
Are there any guru's out there willing to share some LISP or any other sagacious advice??
Replies (8)
Message 2 of 9
pbejse
@Anonymous wrote:
...This is what needs to be adjusted, along with maybe some other block attributes, and the filenames...
What are you asking here EE1337?
Message 3 of 9
john.uhden
PBGV wrote, "What are you asking [for] here EE1337? "
I think maybe a self-starting one-button robotic mower, edger, trimmer. thatcher, leaf blower with optional pooper scooper.
John F. Uhden
Message 4 of 9
pbejse
OR even
A voice activated program that trash, change, mail, upgrade, charge, point, zoom, press, snap, work, quick, erase, write, cut, paste, save, load, check, quick, rewrite, plug, play, burn, rip, drag and drop, zip, unzip, lock, fill, call, find, view, jam, unlock, surf, scroll, pause, then click to terminate the routine.
Message 5 of 9
john.uhden
Plus one that creates a hologram so that your boss thinks you are at your desk working.  You can pass off the sun tan the next day as exposure to graphic screen radiation.
John F. Uhden
Message 6 of 9
Jonathan.Trostad
Hi EE1337,
Changing block attributes is certainly doable, But we would need more information. What is it that you want to change on the existing attribute editor? want to TAB thru the fields? more info? less info?  What items do you want to change? where is the information coming from? - is it the user, or some outside file?
Without some clear ideas of what you actually want, nobody will be able to much...
Message 7 of 9
Jonathan.Trostad
You build a working one of these and I'd for sure buy it... 🙂
Message 8 of 9
john.uhden
A few mapcars and applies and I be done in time for the Spring cleanup.  😕
I've been collaborating with Phil Swift and George Foreman.  It won't leak and will leave your lawn juicy on the inside.
John F. Uhden
Message 9 of 9
This is what I use to change attributes in a block.
(setq pgdesc "Elevation")
  (command "._attedit"	    "_N"	     "_N"
	   "Title Block"    "PAGE_DESCRIPTION"
	   "*"		    "Page Description"
	   pgdesc
