Change Attribute Value by known TAG name
RockyBrown4134
RockyBrown4134
I need some help please with a small routine.
I have a block that has attributes in it called Titleblock_2020. I have a LISP program that we use to insert the title block with default settings. There is one setting I need to have changed based on its Attribute Tag. Manually, its easy to do with ATTEDIT. Sometimes it gets changed, sometimes it doesn't. I wanted to automate it. I have tried several ways but I cant find the easiest way. I may be overlooking something, or I may be over thinking it as well.
Block name: Titleblock_2020
Attribute Tag: ENG_GROUP
Variables:
TBNAME  =  Block Name
DIVNAME  = Company Division Name
I set the DIVNAMEariables in my code.
(setq TBNAME "Titleblock_2020")
(setq DIVNAME "GENERAL ENGINEERING")
Then I tried to edit the attribute.
(command "._attedit" "y" TBNAME "ENG_GROUP" DIVNAME)
This is where I get stuck. Any and all suggestions are welcome.
Thanks.
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
AutoCAD 2020 / Inventor 2020 / Plant 3D
_gile
Since AutoCAD 2012, you can use the  setpropertyvalue function which considers the tag of the attribute as a property of the block reference.
(setpropertyvalue blockEname "ENG_GROUP" "GENERAL ENGINEERING")
Gilles Chanteau
GileCAD
GitHub
RockyBrown4134
Thanks. I knew it had to be something simple.
Ok. I added the code, however I get an error. Am I misunderstanding something? blockEname??
Rocky Brown
RockyBrown4134
Never mind. Stupid me. I answered my own question. I forgot to set the entity name.
Rocky Brown
