Change all xref layer
kidznok
kidznok
I would like to create button which change all xrefs layer using command line.
I have problem how to use qselect to all xref.
Is someone try sth like that?
ВeekeeCZ
-layer color 7 *|*
Edit test
pendean
Community Legend
Community Legend
Change what?
To what?
cadffm
you can not select objects inside a block a block or xref, except you are inside bedit while editing the block or xref.
Qselect can not select layers, just objects, so we don't know what you rwally trying.
If you really try to edit layers, also xref layers, qselect is the wrong command.
Command -LAYER can edit Layers.
Sebastian
ronjonp
Do you mean put all xrefs on a common layer? If so, try this:
(defun c:foo (/ ln s)
  (setq ln "XREFLAYERNAME")
  (if (setq s (ssget "_X" '((0 . "INSERT"))))
    (foreach e (mapcar 'cadr (ssnamex s))
      (if (/= "" (cdr (assoc 1 (entget (tblobjname "block" (cdr (assoc 2 (entget e))))))))
	(entmod (append (entget e) (list (cons 8 ln))))
  (princ)
