Change all hatches with an area bigger then x
sven.deleau
Message 1 of 16
sven.deleau
Goodmorning,
I currently have the following lisp that i use for changing certain hatches.
I tried to add a extra and function for the area of an hatch but i have no idea how.
Could someone help me?
(defun c:solid2dots ( / doc )
   (vlax-for blk (vla-get-blocks (setq doc (vla-get-activedocument (vlax-get-acad-object))))
       (if (= :vlax-false (vla-get-isxref blk))
           (vlax-for obj blk
               (if
                   (and
                       (= "AcDbHatch" (vla-get-objectname obj))
                       (= "SOLID" (strcase (vla-get-patternname obj)))
		       (= "N-CO-BC-BETONVORM-GN" (strcase (vla-get-layer obj)))
		       (> 200 (vla-get-area))
                       (vlax-write-enabled-p obj)
                   (progn
                       (vla-setpattern obj achatchpatterntypepredefined "DOTS")
                       (vla-put-patternscale obj 100.0)
	       (if
                   (and
		       (= "N-CO-BC-BETONVORM-G" (strcase (vla-get-layer obj)))
                   (progn
   (vla-regen doc acallviewports)
   (princ)
(vl-load-com) (princ)
Replies (15)
Message 2 of 16
Kent1Cooper
(> 200 (vla-get-area obj))
Kent Cooper, AIA
Message 3 of 16
sven.deleau
Thanks! didn't notice that, but it doesn't work yet. i get no error whatsoever within autocad
Message 4 of 16
Kent1Cooper
Did you fix it in both places?  [I don't see what the difference is between the two "halves" of the code.]
Kent Cooper, AIA
Message 5 of 16
sven.deleau
Yeah i did 🙂
The difference is 1 letter in the layer name. I tried to use an "And" in combination with "Or" but that didn't seem to work, so i wrote the function 2 times to make it work.
Message 6 of 16
pbejse
@sven.deleau wrote:
Yeah i did 🙂
One obvious reason is the conditions are not met hence no activity
(vlax-for obj blk
               (if
                   (and
		       (member (strcase (vla-get-layer obj))  '("N-CO-BC-BETONVORM-GN" "N-CO-BC-BETONVORM-G" ))
                   (progn
Message 7 of 16
sven.deleau
Thanks for the reply I tested it in multiple situations:
Without the hatch area, it does work with a single layer.
Without the hatch area, it does not work with multiple layers (member function)
With the hatch area it doesn't work in both occasions
What should i do?
Message 8 of 16
hmsilva
Change
to
(> (vla-get-area obj) 200)
Hope this helps,
Henrique
Message 9 of 16
sven.deleau
Sadly it doesn't work. also tried
(< (vla-get-area obj) 200)
Maybe because of units issue
Message 10 of 16
hmsilva
Post the DWG file with some hatches
Message 11 of 16
sven.deleau
Hereby a little snipped of the dwg i have to process
Message 12 of 16
pbejse
 Area (RO) = AutoCAD.Application: Not applicable
What we can do is to add a function to extract the area in another way.
Message 13 of 16
Kent1Cooper
@pbejse wrote:
.... What we can do is to add a function to extract the area in another way.
It doesn't like the (getpropertyvalue) approach, either:
Area (type: double) (RO) (LocalName: Area) = Failed to get value
Kent Cooper, AIA
Message 14 of 16
sven.deleau
haha, i think this is a little bit above my head... i created a lisp which filters the hatch by selection (manually) to provide the current work process. Maybe i will look into this on a later moment with a clear mind 🙂
Message 15 of 16
ВeekeeCZ
Slow and dirty. But the only way I can think of.
(defun c:Blidedots ( / *error* sv ov s i n l a h r x)
    (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if ov (mapcar 'setvar sv ov))
    (princ))
  (setq sv '("clayer" "hpseparate"  "hpname"))
  (setq ov (mapcar 'getvar  sv))
  (setvar 'hpseparate 1)
  (setvar 'hpname "DOTS")
  (if (setq s (ssget "_:L" '((0 . "INSERT"))))
    (repeat (setq i (sslength s))
      (setq n (cdr (assoc 2 (entget (ssname s (setq i (1- i)))))))
      (if (not (vl-position n l))
	(progn
	  (setq l (cons n l))
	  (command "_.-bedit" n)
	  (foreach y '("N-CO-BC-BETONVORM-GN" "N-CO-BC-BETONVORM-G")
	    (setq e (entlast)
		  h (ssadd)
		  r (ssadd))
	    (if (setq x (ssget "_X" (list '(0 . "HATCH") (cons 8 y))))
	      (progn
		(setvar 'clayer y)
		(command "_.hatchgenerateboundary" x "")
		(while (setq e (entnext e))
		  (if (and (not (vl-catch-all-error-p (setq a (vl-catch-all-apply 'vlax-curve-getarea (list e)))))
			   (> a 200))
		    (ssadd e h))
		  (ssadd e r))
		(if (> (sslength h) 0) (command "_.-bhatch" "_s" h "" ""))
		(command "_.erase" x r "")
		  (command "_.draworder" x "" "_b")))))
	  (command "_.bsave")
	  (command "_.bclose")
	  (if (> (getvar 'cmdactive) 0) (command "_save"))))))
  (*error* "end")
Message 16 of 16
ВeekeeCZ
Be interested. Don't be too modest and show off.
