Change all block definitions
de_king
de_king
Hi
I want to change their definition in my DWG for all blocks in the dwg.
-everything to layer 0 and by layer in the definition
-Also the attributes of every block in the definitioni  i want to layer 0 and by layer
thx
Kent1Cooper
See >this<, and modify it as in Messages 17 & 18 there, and also look at other routines in that Topic [if you prefer mine, it can easily be modified to do all Blocks instead of just selected ones].  You will probably find other such routines with a little Searching.
Kent Cooper, AIA
komondormrex
hey,
check this
(defun c:all_blocks_0_bylayer nil
	(vlax-map-collection (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
		'(lambda (block_definition)
		 	(if (and
			      	(zerop (vlax-get block_definition 'islayout))
			      	(snvalid (vla-get-name block_definition))
			   	(vlax-map-collection block_definition
					'(lambda (object)
					 	(progn
							(vla-put-layer object "0")
						  	(vla-put-color object 256)
  	(vla-regen (vla-get-activedocument (vlax-get-acad-object)) acactiveviewport)
  	(princ)
de_king
thanks already
solution partially works
only the blocks may go to layer 0 and color by layer...everything has been changed
komondormrex
sure. layouts. check update.
de_king
it works for most of my blocks
But i have blocks where i have to do an attsync first
Strange because attsync is only for the attributes i thaught?
There are polyline changing from color after using attsync, never seen this
( I have used dynamic blocks also)
