Chamfer 45°
Chamfer 45°
Rikkes
Message 1 of 1
Chamfer 45°
Rikkes
Is it possible to create a command (lisp) to chamfer automatic a 3D solid edge 45°?
I work in the furniture business and i have to chamfer a lot of boards in an 45° angle.
I'm looking for a simple command that cuts a chipboard (for example) in that angle just when i select the corner to cut of, just like i would do so on a machine. At this moment, i have to give the distance of the two sides and chose the edge. That takes to long. I would like to do it more simple. Just chose the command and click on the edge. It has to chamfer it over the whole height of the solid at a 45° angle. If the solid is 19mm heigh, it must cut 19/19, if ist is 25 heigh, it must cut 25/25.
It must detect the hight of the smallest side and use this value.
Capice?
This command would save me a lot of time!
Replies (0)
