Centroid Property Preciscion
Julio_Soto
Advisor Advisor
Julio_Soto
When I dump the properties of some 3d solids I notice the Centroid property only shows 1 decimal place of precision. It shows this no mater what I set my units to. Is this correct?
Moshe-A
@Julio_Soto  hi,
As far as can see the 'Centroid' has it's internal accuracy level. if it's xxxx.0 then it's 0.000
if it's xxxx.5 that its 0.500 etc.
try to change a bit the 3dsolid and see if this true?!
Moshe
CADaSchtroumpf
Use (rtos) for have the max digits.
((lambda ( / ss Obj Centroid)
	(while (not (setq ss (ssget "_+.:E:S" '((0 . "REGION,3DSOLID"))))))
	(setq
		Obj (vlax-ename->vla-object (ssname ss 0))
		Centroid (vlax-Get Obj 'Centroid)
	(princ
		(strcat
			"X=" (rtos (car Centroid) 2 16)
			" Y=" (rtos (cadr Centroid) 2 16)
			(if (caddr Centroid)
				(strcat " Z=" (rtos (caddr Centroid) 2 16))
	(prin1)
