Centrelines for selected rectangles along major axis without extra offsets
Dear Experts,
Need small change in below code, the code shall generate center lines along major axis only, without any extra buffer on both sides.
(defun c:DC (/	 lt  ename   b	 c   sn	 sn1 sn2 p1  p2	 p3  p4	 f
     d	 d1  d2	 d3  a1	 a2  a3	 a4  p5	 p6  p7	 p8  p9	 p10
     sc
 (command "cm?decho" (getvar "cmdecho"))
 (setq lt "center")
 (if (= (tblsearch "ltype" lt) nil)
   (command "-linetype" "l" lt "acad.lin" "")
 (princ "\n Select rectangles: ")
 (setq	ss  (ssget '((-4 . "<and")
	     (0 . "LWPOLYLINE")
	     (70 . 1)
	     (90 . 4)
	     (-4 . "and>")
sn  (sslength ss)
sn1 sn
 (repeat sn
   (setq sn2	(1- sn1)
  ename	(ssname ss sn2)
  b	(entget ename)
  b	(member (assoc 10 b) b)
   (while (member (assoc 10 b) b)
     (setq c (append c (list (cdr (assoc 10 b))))
    b (cdr b)
   (setq f   0.125
  d   0.12
  p1  (nth 0 c)
  p2  (nth 1 c)
  p3  (nth 2 c)
  p4  (nth 3 c)
  c   nil
  d1  (/ (distance p1 p2) 2)
  d2  (/ (distance p2 p3) 2)
  d3  (if (> d1 d2)
	(* d1 0.12)
	(* d2 0.12)
  a1  (angle p1 p2)
  a2  (angle p2 p1)
  a3  (angle p2 p3)
  a4  (angle p3 p2)
  p5  (polar p1 a1 d1)
  p6  (polar p5 a4 d3)
  p7  (polar p6 a3 (+ (* d2 2) (* d3 2)))
  p8  (polar p2 a3 d2)
  p9  (polar p8 a1 d3)
  p10 (polar p9 a2 (+ (* d1 2) (* d3 2)))
  sc  (* (+ d1 d2) f)
  sn1 sn2
   (entmake (list
       (cons 0 "LINE")
       (cons 6 lt)
       (cons 62 3)
       (cons 10 p6)
       (cons 11 p7)
       (cons 48 sc)
       (cons 210 (list 0.0 0.0 1.0))
   (entmake (list
       (cons 0 "LINE")
       (cons 6 lt)
       (cons 62 3)
       (cons 10 p9)
       (cons 11 p10)
       (cons 48 sc)
 (princ)
ВeekeeCZ
You should be able to do this on your own, really.
(defun c:DCentrer (/	 lt  ename   b	 c   sn	 sn1 sn2 p1  p2	 p3  p4	 f
     sc
 ;(command "cm?decho" (getvar "cmdecho"))
 (setq lt "center")
	     (0 . "LWPOLYLINE")
	     (70 . 1)
	     (90 . 4)
	     (-4 . "and>")
sn  (sslength ss)
sn1 sn
 (repeat sn
   (setq sn2	(1- sn1)
  b	(entget ename)
    b (cdr b)
   (setq f   0.125
  d   0.12
  p1  (nth 0 c)
  p2  (nth 1 c)
  p3  (nth 2 c)
  p4  (nth 3 c)
  c   nil
  d3  (if (> d1 d2)
	(* d1 0.)
	(* d2 0.)
  a1  (angle p1 p2)
  a2  (angle p2 p1)
  a3  (angle p2 p3)
  a4  (angle p3 p2)
  p5  (polar p1 a1 d1)
  p6  (polar p5 a4 d3)
  p8  (polar p2 a3 d2)
  p9  (polar p8 a1 d3)
  sc  (* (+ d1 d2) f)
  sn1 sn2
   (if (> (distance p6 p7)
          (distance p9 p10))
     (entmake (list
       (cons 0 "LINE")
       (cons 6 lt)
       (cons 62 3)
       (cons 10 p6)
       (cons 11 p7)
       (cons 48 sc)
   (entmake (list
       (cons 0 "LINE")
       (cons 6 lt)
       (cons 62 3)
       (cons 10 p9)
       (cons 11 p10)
       (cons 48 sc)
 (princ)
btw there are quite a few question marks in the code which probably should not be there.
