Centerline between two 3D lines
k_l_raghava
k_l_raghava
Need Help in getting Centerlines between 3D polylines(road edge lines).
Annotate-> Centerline command not recognizing the 3D polylines as a line (even tried flatten command on those but still same issue).
form my knowledge the option i have made is making lines joining the vertices of selected (parallel/non parallel) lines and drawing the perpendicular to second one in the pair and then joining the center points to get center line.
Can any one suggest a lisp - as my total polylines length is about 400 kms (800 kms of road edge lines).
attached is a sample bit of problem drawing.
Thanks in advance.
dlanorh
This may be helpful. Follow the link in the last post HERE
I am not one of the robots you're looking for
ВeekeeCZ
Just tested quickly.
You still need to flat them, explode and rejoin to get lwpolylines.
btw the routine was also posted HERE
k_l_raghava
is there no option without converting to LWpolylines ??
as i explained, my drawing is covering a big city roads, if i explode-flatten-join it is almost impossible task.
can there be a routine to average the verticies z value and average them to give the z value in center line vertex.
ВeekeeCZ
You know what... better get some better computer because converting polylines it's a piece of cake comparing to processing algorithm finding their centrelines.
The truth is, that rather than exploding and rejoining workflow would be more efficient to do the job directly - maybe THIS  routine by _gile.
vladimir_michl
If I understand the question, it is not about a centerline symbol but rather about an axis curve (an average curve between 2 existing curves). The CurveAxis LISP tool (freeware) supports also 3D curves.
See CAD Forum - How to create an axis of two curves? (average curve)
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
Kent1Cooper
See the accepted solution in the other thread in which this is one part of the topic.
Kent Cooper, AIA
