Center Point of an Arc I just made
emoran6CG9J
emoran6CG9J
Im a little new to LISP in general and I am trying to make a arc leader LISP as a small project for myself.  Currently I have made an arc using the 3 points the user need to input.  I could like to make the arrow out of a shape and point the arrow in the direction tangent to the end point of the arc.
Based on how I want to use the geometry I need to get the center point of the arc I just made.
my question is:  how can I select the center point of the arc I just made?  Ideally I would like get the centerpoint of the arc and throw it into a variable that I can use for the geomerty calculations.
This is what I have so far.. I know its kinda basic:
(defun C:artic ( / PT1 PT2 PT3)
    ; GET INITIAL POINTS AND MAKE ARC
    (setq PT1 (GETPOINT "/nPICK START POINT: ")
      PT2 (GETPOINT "/nPICK MIDDLE POINT")
      PT3 (GETPOINT "/nPICK FINAL POINT")
(COMMAND "ARC" PT1 PT2 PT3)
pendean
Community Legend
Community Legend
First 10-ish top links in their search I suspect is enough to get you started https://www.google.com/search?q=autocad+arc+leader+lisp
Assuming you already looked into using a Dynamic Block possibly with a parametric action and it did not meet your needs.
Kent1Cooper
(setq YourArcCenterVariableName (cdr (assoc 10 (entget (entlast)))))
Kent Cooper, AIA
emoran6CG9J
Wow okay, so I see what you did to get the last entity that was made.
Where can I find the documentation of the formatting of this entity data?  I see all of the properties that you filtered out with the "10" which I assume is the 10 for the center point information.
Im looking through the developer directory but I am having trouble looking up information on entities and parameters for standard ACAD commands.
Thank you for helping me out with this
Kent1Cooper
You can find the DXF codes [such as that 10 for the center of an Arc, Circle or Ellipse] >here<.  The AutoLisp functions reference is >here<.
Kent Cooper, AIA
