center of gravity
center of gravity
center of gravity
I have a lisp witch calculates the center of gravity of a polyline.
(defun ax:Centroid (poly / pl ms va reg cen)
(vl-load-com)
(setq pl (vlax-ename->vla-object poly)
ms (vla-get-modelspace
(vla-get-activedocument (vlax-get-acad-object))
va (vlax-make-safearray vlax-vbObject '(0 . 0))
(vlax-safearray-put-element va 0 pl)
(setq reg (car (vlax-safearray->list
(vlax-variant-value (vla-addregion ms va))
cen (vla-get-centroid reg)
(vla-delete reg)
(vlax-safearray->list (vlax-variant-value cen))
(Defun c:zwaartepunt()
(setq punt (ax:Centroid (car (entsel))))
(princ "\nZwaartepunt is (x y): ")(princ punt)
(princ)
now the output is like: Zwaartepunt is (x y): (125058.0 -23818.9)
but can i automate it with drawing a circle with that center and a rudius of like 50mm or something?
dlanorh
Try this. Additions are in red. Change rad to reflect your circles radius.
(vl-load-com)
        ms (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
  (setq reg (car (vlax-safearray->list (vlax-variant-value (vla-addregion ms va))))
  (vla-delete reg)
(defun c:zwaartepunt()
        rad 5.5
  (command "_circle" punt rad)
(princ)
I am not one of the robots you're looking for
super .. its does the trick!
Kent1Cooper
No need for a variable that is used only once -- just give it the radius value directly:
(setq punt (ax:Centroid (car (entsel)))) (command "_.circle" "_non" punt 50) (princ "\nZwaartepunt is (x y): ")(princ punt) ....
[I also added the "none" Object Snap to prevent problems if you have running Osnap modes on.]
Kent Cooper, AIA
