capture for the same profile
ptdesign
Message 1 of 10
ptdesign
hi
Is anybody able to support me write a Lisp for me?
This Lisp is to capture for the same profile & will highlight out if the profile is same. (pls refer attach file)
Replies (9)
Message 2 of 10
hak_vz
Try this.
Run command sameAreaPoly , select starting profile and all profiles with same area will be colored red.
Depends on precise drafting but should work OK. Otherwise I don't see method that would
find what requested. Eventually one may look for pairs of intersecting dimension lines) but it
would be much complicated.
(defun c:sameAreaPoly ( / e eo ar ss i mo)
(setq e (car(entsel "\nSelect base profile >")))
(setq eo (vlax-ename->vla-object e))
(setq ar (vlax-get eo 'Area))
(setq ss (ssget "x" '((0 . "LWPOLYLINE"))))
(setq i -1)
(while (<(setq i (1+ i))(sslength ss))
	(setq mo (vlax-ename->vla-object (ssname ss i)))
	(cond
		((equal ar (vlax-get mo 'Area) 1e-5)
			(command "_.chprop" (ssname ss i) "" "Color" 1 "")
(princ)
If this works, accept this as a solution.
Miljenko Hatlak
Message 3 of 10
ptdesign
Hi
Your lisp is working by picking one profile only,
But some profile is same but no highlight out, can I request it can select all the profile?
Then if is same then can highlight difference color.
Please advise
Ang
Message 4 of 10
hak_vz
@ptdesignIn your second sample you have mixed LWPOLYLINES amd POLYLINE object so code didn't work properly.
Now it will select all entities with same area. I'm currently at work so can not help but you can use this updated code to, step by step, filter your profiles or do what ever you need. If changes needed try to give more details and I'll work on it later today.
(setq ss (ssget "x" '((0 . "*POLYLINE"))))
(setq i -1)
	(cond
		((equal ar (vlax-get mo 'Area) 1e-3)
(princ)
Miljenko Hatlak
Message 5 of 10
hak_vz
___
Miljenko Hatlak
Message 6 of 10
ptdesign
HI Hak
some profile cannot capture.(refer my attach file)
Please advise
Message 7 of 10
hak_vz
In this line you can change tolerance 1e-3 to 1e-2
Sometimes mister Murphy gets involved. You know who I'm talking about.
Miljenko Hatlak
Message 8 of 10
Kent1Cooper
Might it ever happen that you would have some with the same area, but not the same shape?
The left one is 4 x 6 units, and the right one 3 x 8, so both have the same area of 24 square units minus the rounded corners.  [And of course there are an infinite number of other shapes that could have the same area.]  Since the suggestions so far compare only area, whichever of those you pick on, it will highlight both.  Should it also evaluate the shape somehow?  Even if only the width and height?
Kent Cooper, AIA
Message 9 of 10
ptdesign
HI Hak
I think your lisp is good, now I can be used.
thanks a lot,
ptdesign
Message 10 of 10
hak_vz
Hi @ptdesign
There is probably some better method to do this test, but if this works than we should be satisfied.
Miljenko Hatlak
