Cannot Rotate Model when Performing Editor.GetSelection
mujibur.rahman
mujibur.rahman
I want select objects from Model Space by passing command
Dim acSSPrompt As PromptSelectionResult = acDocEd.GetSelection()
when this command is passed, it prompts the user 'Select Objects: ' in the Model Space
I want to rotate(3D Orbit) the Model to select the objects that are hidden by the other
please help me in this......
_gile
The few lines of code you show does not allow to diagnose your issue.
You should be able to orbit during  a selection with Editor.GetSelection() except, perhaps, in some context e.g., calling the method from a modeless dialog (or palette).
See this recent topic.
PS: this is the LISP forum here, you should have posted in the .NET one.
Gilles Chanteau
GileCAD
GitHub
mujibur.rahman
Very Thanks for your reply.
I am using modeless dialog form.... that's why I cannot rotate the model or access any commands....
_gile
You probably could if you follow Kean Walmsley advice:
"Once again there’s our important rule of thumb when it comes to implementing a modeless UI: rather than manually locking the current document, it’s safer to define a command – which will implicitly lock the current document – and call that from the UI via SendStringToExecute()."
Gilles Chanteau
GileCAD
GitHub
