Cannonscale setvar
Cannonscale setvar
whitney_jeff
Message 1 of 8
Cannonscale setvar
whitney_jeff
Accidentaly used the wrong name for my original post
I have a setup lisp routine that creates a scale factor - I would like to pass that on to cannoscale, but cannoscale seems to only recognize architectural formats such as 1/8" = 1'-0".
The test expression (if (=  sf 96) would be the start of the expression (sf is my scale factor) - but I cannot figure out how to pass the arch scale 1/8" = 1'-0" on to cannoscale in a setvar statement.
I tried (setvar "cannoscale '1/8"=1'-0") but it seems the second quote mark messes it up.  How can I get around this?
Many thanks!
Replies (7)
Message 2 of 8
dbroad
(setvar "cannoscale '1/8\"=1'-0")
put a backslash to escape the quote.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 8
whitney_jeff
returns "too many arguments"
I tried (setvar "cannoscale" '1/8\"=1'-0")
(setvar "cannoscale '1/8"=1\'-0")
and other variations
Message 4 of 8
hmsilva
Hi Jeff,
try
(setvar 'CANNOSCALE "1/8\" = 1'-0\"")
there are spaces and a last "
Hope this helps,
Henrique
Message 5 of 8
whitney_jeff
There is no joy in Muddville Smiley Embarassed
The leading single quote I have (') is equal to (quote), but the second single quote used as the foot mark (1') as well as all the double (") quotes (inch marks) really seems to mess everything up.  I wonder if I would be better off doing a setq for the scale and then using something like (setq 1-8 "1/8\"=1\'-0\"") and then (setvar "cannonscale" 1-8)?
Message 6 of 8
dbroad
Sorry, I didn't look at your code closely enough.  setvar takes 2 arguments, the variable name and the value.  There are two possible ways to enter the variable name, 1)as a double quoted string, or 2) as a single quoted variable
(setvar 'cannoscale "1/8\" = 1'-0\"")
or
(setvar "cannoscale" "1/8\" = 1'-0\"")
The value cannot begin with a single quote because cannoscale must have a string.  In addition, the name must be exact with spaces.
Before coding, I suggest using getvar as in
(getvar "cannoscale")
"1/8\" = 1'-0\""
It will show you exactly what to type if the annotation scale is already set.
Message 7 of 8
whitney_jeff
DB - that worked.  I swear I tried that combination and it bombed.  AutoLISP - go figure!
Thanks for your help and patience!
Message 8 of 8
dbroad
You're welcome.
