Cann't accoreconsole open script file(*.scr) in a network location?
TiStars
Advisor Advisor
Message 1 of 11
TiStars
I wrote a bat file to call accoreconsole to open the other script file.  If i put script file in to a shared network drive, I got error message of
"**** System Variable Changed ****
1 of the monitored system variables has changed from the preferred value. Use SYSVARMONITOR command to view changes.
Command:
Command: File load canceled: h:\temp\1.scr"
As you see, H: is a shared drive.
if I put 1.scr to local drive "c:\temp\1.scr", it can be run correctly.
Thanks  for any idea or suggestion!
Below is my simple bat:
cd "C:\Program Files\Autodesk\AutoCAD 2016"
c:
cls
accoreconsole.exe /i "H:\temp\follow river.dwg" /s "H:\temp\1.scr" /l en-US
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
Replies (10)
Message 2 of 11
I run AcCoreConsole with network scripts all the time.
Open the drawing, then try to run the script from the network
. If it runs okay, my guess is there is something wrong with the BAT file.
Message 3 of 11
TiStars
Thank you,
the script runs very well from the network and local drive when I drag and drop it to opened drawing.
for the BAT file, I don't understand that:
[/i "H:\temp\follow river.dwg" ] ⇒this part runs well , but
[/s "H:\temp\1.scr"] ⇒this parts goes wrong.
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
Message 4 of 11
cadffm
Are you sure the name of script file is "1" ?
please create a simple BAT like this:
REM - START
"C:\Program Files\Autodesk\AutoCAD 2018\accoreconsole.exe" /i "H:\temp\follow river.dwg" /s "H:\temp\1.scr"
PAUSE
REM - END
a simple Script like this
;; Start
LOGFILEPATH
H:\temp
LOGFILEON
_CIRCLE
50,50
15
;; End
In the console-windows[C:\.], in the first 1-2 lines you have to check the Path+Filename+Extension information of your Scriptfile,
are the path+file+extension string well displayed in the console window, or not?
Where/What Error appears?
Current we dont know your BAT and SCR content, we dont know the console feedback and not the Logfile, so it is really hard to say.
Sebastian
Message 5 of 11
TiStars
I am sure the name of script file is "1" as I made it. It's a simple script to plot drawing to PDF which I use to learn script file. it runs very well when i drag and drop it to an opened drawing , also when put on a local drive C:\  and called by a bat file.
but I still tried your simple Bat & Script file and got same error.
I attached them and error log for your reference.
btw, script file did nothing as it has not been opened.
Thank you very much!
bat & scr file cannot be attached , so i paste here :
bat file(a bit change from your sample bat):
REM - START
"C:\Program Files\Autodesk\AutoCAD 2016\accoreconsole.exe" /i "H:\temp\Isolation Valve.dwg" /s "H:\temp\test.scr"
PAUSE
REM - END
scr file(same with your suggestion):
;; Start
LOGFILEPATH
H:\temp
LOGFILEON
_CIRCLE
50,50
15
;; End
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
Message 6 of 11
cadffm
hmm i am not sure, but one thing looks crazy:
Your BAT should open a file "H:\temp\Isolation Valve.dwg" but in your test.log the coreconsole open a file name "H:\temp\IsolationValve.dwg" (without the blank/space) ???
I think a can not help at this point, it isn't possible to test it 1:1 on my computer and now i am out.
-Test it with a blank/new file
-Try to fix the problem of these feedback:
"Unable to access Shared Pipe Catalog folder. Please verify configuration." ..
And for testing start *.bat file ever with doubleclick (not by 3.part programm)
Sorry Sebastian
Sebastian
Message 7 of 11
TiStars
Hi Sebastian,
Sorry I didn't provide all the information.
There are no blank/space in the "H:\temp\IsolationValve.dwg" is because I deleted them. For some reason, extra blank/spaces has been outputted to the log file , between every 2 letters.
I tried to fix it by remove all extra blank/spaces , but unfortunately, I remove some original spaces . that's why the filename became "IsolationValve.dwg" without blank/space.
I will refer to feedback you suggest, thank you very much
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
Message 8 of 11
TiStars
This issue has been resolved after I added the path of scr to "Trusted Loactions".    H drive is a net drive as mentioned above.
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
Message 9 of 11
ams0803
Community Visitor
Community Visitor
hi I know this is an old issue you had. I am running to the same problem now. I added the drive to Trusted Locations and it is still not loading the src. Did you do anything else to fix this? Any help would be appreciated.
Message 10 of 11
cadffm
please, share screenshots of your trusted path setting
and the full path in win explorer
Sebastian
Message 11 of 11
TiStars
I don't remember I did anything else, It should be working well once it works.
Would you mind sharing some more info like @cadffm suggests?
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
