Can you modify this LISP to chamfer instead of fillet?
masumiNYMDW
masumiNYMDW
I'd like to make this LISP to chamfer @100, 100 distance as I draw a polyline.
I think we can use the LISP below to add the necessary modifications.
Probably we can register the new LISP as PLC?
I'd appreciate it if someone could take a look at it because I'm very new to LISP.
(defun C:PLF ()
(command "_PLINE")
(while (= 1 (getvar "cmdactive"))
(command pause))
(command "._FILLET" "P" "R" 100 "L")
(princ)
LDShaw
Works like the one you posted.
(defun C:PLC ()
(command "_PLINE")
(command pause)
(command "._CHAMFER" "D" "100" "100")
(setq pline (entlast)) ;; Get the last created polyline
(command "._CHAMFER" "P" pline "")
(princ)
Kent1Cooper
Do you mean to Chamfer every corner as you go along?  [The suggestion made already does it after the Polyline is drawn with as-yet-un-Chamfered corners.]
For Filleting, I wrote PlineFilletAlong.lsp, >here<, that does the Filleting of each corner as you go along.  I imagine it could be modified to Chamfer instead, if that's what you're looking for.
Kent Cooper, AIA
masumiNYMDW
Love it! Thanks!
masumiNYMDW
You are right. "After finishing writing a polyline by pressing enter" was a more accurate request. Thank you!
